Runaway diesel
   / Runaway diesel #1
Big Bri
Kubota MX5100
I just bought a used grasshopper 722dt6 with a 3 cylinder diesel. Engine only has 350 hrs. The first two times I cut my yard she performed flawless. Yesterday while cutting the mower would slow down while going up hills to the point of almost dying. (Motor would slow down) I called grasshopper today while at work and they said to
1, change filters
2, drain the fuel tank and start with new fuel and give it a try.
that didn稚 help
next
if that didn稚 work I was told to take off the supply line out of the tank and check for leaks ( put thumb on one end and blow) no leaks there.
so I put It back together and added a little power service clear diesel to see if it might clean an injector
well when I started the mower it went full tilt and I had to pull the air cleaner and shove my shirt into the intake to stop it.
i have since drained the tank and added new diesel from a different store and she still wants to run away.
any ideas?
Thanks for the help
   / Runaway diesel #2
Injection pump fuel rod is stuck. A least that's my guess from my experience.
   / Runaway diesel #3
Having experienced a stuck fuel rack myself that would be the first thing I checked. Take the governor housing off and see if the fuel rack control rod freely moves in and out. It should move pretty much effortlessly. If it doesn't, you have a stuck fuel rack. As long as it is just a gummed up rack and not stuck because of a mechanical part failure, it will be easy to free with a little patience and a good penetrating oil. It could be a stuck governor too but you will figure that out as soon as you remove the governor housing. I am just assuming you already checked the throttle cable.
   / Runaway diesel
I’ve never messed with an injector pump so this will a new venture for me. Will look at it tomorrow
   / Runaway diesel
I did look at the throttle cable and governor and both seem to be working fine. Thanks
   / Runaway diesel #6
I hadn't either until this year. I had always been told to never touch them because our shop required a certified tech to touch them. Of course, that was until thepumpguysc told me I could fix my own as long as I didn't touch the wrong things. He walked me through the process on here. If you find the rod doesn't move well at all, I can post my write up on what I did to fix mine after listening to thepumpguysc's advice.
   / Runaway diesel #7
Thanks mercdv.. It kinda depends on which type of injection pump he has.. it might be easier than yours to un-stick.
IF you could post a pic of the pump & engine, that would be GREAT..
I know it might be "tricky" to put a pic on the site, so I'll send you my email address..
THAT WAY.. if you have it on your phone, you can send it quicker..
   / Runaway diesel
3E230EE0-10B0-4A12-B04B-D7669C32AFE6.jpeg6009C471-E06F-4435-9EF0-EE66428DAEB7.jpeg36B806F4-9637-4B06-A1DF-02EA196ABD47.jpeg3468980B-0D66-4A84-8145-0D5E91F7D01C.jpeg
Here are the pics as requested. I messed around with it a little this morning before going to work. The in the video you can see movement is limited. Thanks again
   / Runaway diesel
Apparently I can’t up load a video, here are some picks of the limited movement.01F9D42E-665D-4736-B432-2AA77593F975.jpeg7ED6AE7F-7080-45F9-938F-849389CF9BE8.jpeg
   / Runaway diesel #10
Is it sticking due to the shutoff solenoid (top right in the last picture) linkage being twisted and jamming?
Aaron Z
TUGGER TRAILER (A58214)
TUGGER TRAILER...
New/Unused Quick Attach Pallet Forks (A57453)
New/Unused Quick...
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A56436)
2023 Kubota...
(3) 12/2 NM-B Copper Clad Aluminum (A57454)
(3) 12/2 NM-B...
2009 GMC Sierra Pickup Truck, VIN # 1GTEC14X29Z187521 (A57453)
2009 GMC Sierra...
