Fallon
Super Member
Hi Zing,
You are entirely welcome, I'm just glad it helped someone.
My truck is very old- no TPMS, except me.
My Honda Element has it, and I hate it- the light has now been on for about 2 years, ever since about a week after I had new tires installed, it was fine for that time, then the light came on, even though a quick pressure check showed that the tires were all fine.
On the Honda Element Owners Group forum there are discussions about how to disable [or at least black out the space over it with electrical tape] the idiot light- but I'm too tired and old to be disassembling the dash on an otherwise perfectly-working vehicle for an annoying light.
There were once some rumors that having the sensor tripped could affect traction control or the cruise control, but I haven't had any such problems, so there it sits.
The main reason I didn't get new sensors put in is two-fold:
1) Cost- about 85$ per tire for the sensor and then the labor for taking the tire off the rim, doing the install, and then having to calibrate them, and register them to the on-board module- ask me how I know....
2) It turns out that they are made en mass and then shipped out to local areas- WITH THE BATTERY IN PLACE AND ACTIVE- meaning depending on how long they have been sitting on the shelf, they could run out of charge a day after being installed- especially for a not-very-popular model /size that sat on the shelf for a few years or more before being used...
You should think about installing a portable 12-V compressor [or a 110-V AC compressor with a power inverter] on your truck so you can air up whenever you decide/need/want to haul something...
They generally have a switch activated by centrifical force. So they are mostly or completely in sleep mode until the wheel starts spinning.
But ya, they are a pain. Have a 2nd set on the snow tires/rims. Les Schwabs replaced a pile of those sensors in the first couple years as they had issues. Luckily I only had to pay for one replacement on my original rims, the rest were on the nmsnow rims.
