Making some Battery cables
/ Making some Battery cables #21
Did you read crimped AND soldered?
Did you read the first paragraph of post #8 ??
it is most germane to the topic of the thread...i.e., BATTERY CABLES...
If you ask lead/acid battery professionals they will tell you the best method is tinning (solder) the ends that go into closed end connectors then crimping...
/ Making some Battery cables #22
Seriously doubt you will find soldered battery cables here....
Dale
/ Making some Battery cables #23
It's OK...there are still people that think the world is flat...LoL...!
/ Making some Battery cables #25
You really should give up on the flat earth theory, science has proved you wrong....
Dale
heheh...I'm not the one that's denying beyond reproach, factual proof...doh! :laughing:
btw...your last response (cited) is a type of psychological projection...I would direct you the actual definition but your reading comprehension skills are obviously lacking...and you probably wouldn't understand it anyway...
/ Making some Battery cables #27
Here is an explanation and graphic proof that soldering is indeed the better way to assemble cables...
Granted tractors/ automobiles etc. do not generally employ deep cycle, multi voltage cycle type activity but the same theory applies to standard agricultural or automotive applications...
scroll down to just above half way to see the graphic proof...
http://www.trojanbattery.com/pdf/WP_BatteryCableGuide_0512.pdf
You did not mention crimping in the post.
If you mean to solder AND crimp you should state it.
/ Making some Battery cables #28
The post instructed to a specific page that stated the point...!
Again...I had already made my thoughts clear (if you can remember?, it's a fairly short thread)...both in an early post (#8) and within the link I cited before the fact as well as the one following...
I admit it... but your gripe is a petty technicality...
/ Making some Battery cables #30
Crimp and solder all large gauge DC or battery connectors. My Plato SP-500T solder pot ensures there is NO COLD SOLDER joints.
David
/ Making some Battery cables #31
I'll just add my $.02. I worked/lived on a golf course for a long time. We crimped and soldered all copper battery connections but only crimped larger aluminum connections. We would have preferred to crimp and solder the aluminum but it was just easier to slap on some oxide inhibitor and crimp it. That way we didn't have to worry about someone over heating the aluminum since we had a bunch of teenagers working in the shop. The crimping and soldering held up in the golf carts and other equipment better and we had less cable related issues.
2017 CATERPILLAR 980M WHEEL LOADER (A62129)
2017 CATERPILLAR...
New 20'x20' All Steel Carport (A62679)
New 20'x20' All...
2018 HINO 338 KNUCKLE BOOM TRUCK (A63276)
2018 HINO 338...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
LS MT225E (A64126)
LS MT225E (A64126)
New Quick Attach Power Spreader (A65579)
New Quick Attach...
