D
Deleted member 314313
Guest
The fact that threads and holes are damaged, means it was operated while loose. Just cause the bolts were torqued, doesn't mean that things were properly/tightly seated together. If the tire wasn't off the ground, it could have been on a bind that didn't allow the "proper torque" to pull it together. Such things require closer observation than a "good walk around". You also need to take things like "tractor weight" and "the earth" out of the equation when checking torque on such things.
Of course the bolts were loose that's why they came out. Now I've heard it. The bolts were torqued to spec. 96ftlbs on level ground.
The problem wasn't the earth or tractor weight. The problem is bolt stretch over painted surfaces in addition to lack of Loctite and the design of the lug bolts. A good walk around by me would have identified loose bolts. I have heard of several Mahindra 3550 front tractor tire bolts falling out. It's the design of the bolt against the rim that assists them loosening. Have other tractors with different lug design and rims, they have never gotten loose much less fallen out. Thanks for the input. Keep checking them lugs.
