Fuel Transfer Pump
/ Fuel Transfer Pump #1
TheMan419
Indiana
New Holland Boomer 24
Ok so I am looking to upgrade from the standard 5 gallon diesel can. Or possibly modify the can. However my google skills seem to be lacking.
I am looking for a cheap pump to transfer the fuel from the can into the tractor. It does not need to be electric, a hand pump is fine. I'd rather not have it be gravity operated. Looking at what I can find they are all either very expensive powered options or gravity.
I currently have just 1 five gallon can. It is just not enough. I was thinking of either buying a "caddy" that holds 15 gallons or so or getting another couple 5 gallon cans. However with these new EPA approved "improved" cans it takes too dang long to empty them into the tank. I don't like holding them up there that long. So I figure if I am going to upgrade why not go a bit better and just not have to lift the cans at all.
And no I am not going to get a 55 gal drum. I am a hobby farmer and do not use that much fuel to make that a solid idea.
Any one got a good tool for this job?
/ Fuel Transfer Pump #3
This is a handy little pump;
https://www.northerntool.com/shop/tools/product_200612558_200612558
Or you can take a regular automotive 12 volt fuel pump and add a suction hose and a discharge hose and filter,
that is what I rig up in the winter to fill my salamander heater from a 15 or 55 gallon drum that I fill with a blend of K1 and #2, I keep the 15 gallon with straight K1 the 55 is blended.
/ Fuel Transfer Pump #5
This is your lucky day as I have the answer. It's called "The Pocket Pump' here in Canada and sells for $30.00. I've tried many of the other "super siphons" or whatever and all are garbage as far as I'm concerned. I got so frustrated as to buy a 12 volt $400 Fill Rite pump just to fill my tractor, lawn mower ,ATV and snowmobiles. What I did with it was to mount it on a bench in my gas shed with a flexible pick up hose that I could stick into a 5 gal can of gas or diesel. This would be better for a more industrial setting than the Pocket Pump. Back to the Pocket Pump I have used it weekly for 2 years, winter and summer with no issues. Probably only used 2 or 3 sets of batteries. Buy extras when you buy the pump to have them on hand. There are 2 models. I think the one without the nozzle control is better . Less to go wrong and when you use it you have one hand on the hose anyway and the other on the switch on the handle. The hose might be slightly longer on this, the cheaper model. Going to sell my super reliable $400 pump. The web site for the pump doesn't seem the greatest to me so search around.
Look here to start. Pocket Pump Ltd. - Heavy Duty All Purpose Pump
Al
/ Fuel Transfer Pump #6
I know you say you don’t need a big setup, but don’t discount a truck mounted tank if you have one (truck). I use a 37 gallon tank in my truck with a fill rite pump and filter. You just can’t beat the convenience, plus the fuel gets filtered, and I’m not messing with lifting cans.
/ Fuel Transfer Pump #7
I use this product:
Amazon.com: TeraPump A-TREP3-1 TREP3 Multi-Purpose Powered Liquid Transfer Pump - 11V AC/12VDC, 4 GPM: Automotive
You can keep the can on the floor and pump fuel up into the tank. Works on 110V in the shop or 12V in the field.
It is also approved for gasoline which many small electric pumps aren't.
I use it with a 25 gal poly tank which I put in an old wagon. I load it into my pickup with the tractor FEL and fill it with off road diesel at the truck stop. It sure beats hauling those 5 gal cans around.
/ Fuel Transfer Pump #8
I use one of these rotary hand pumps in a 30 gallon barrel. I believe they would also work in a 15 gallon barrel. Like BD I use the loader for moving the full barrel and purchase off road diesel. No electricity required.
GPI Hand Pumps
/ Fuel Transfer Pump #9
Al
Will the Pocket Pump suction pipe fit in the opening of a standard 5 gal. (US) gas/diesel can?
/ Fuel Transfer Pump #10
I bought a 12 volt diesel pump of Ebay for $20 or $30. Then I bought a 180 liter steel drum. Works great, pumps nearly as fast as the gas station. The pump fits in the bung hole of the drum. Also perfect for pumping a vehicle diesel tank.
/ Fuel Transfer Pump #11
Yes. The Pocket Pump has no fittings . Just stick it in the hole in the can, pail or whatever. The pump is at the bottom of the shaft so always primed and ready to go.
Al
/ Fuel Transfer Pump #12
Excellent!
Thanks Al.
Apparently some Home Hardware stores (not all) have these.
I will see if I can get my local HH get one for me, when I get to my summer cottage in Nova Scotia next week.
/ Fuel Transfer Pump #13
Harbor Freight carries the Battery Operated Liquid Transfer Pump for $9 before discount. Seems identical to the "pocket pump", I've used one to fill/empty my 50 gallon transfer tanks. (pocket pump seems like what you do when you play pocket pool :) )
But I usually use 5 Gallon cans and just lift them on to the hood and use a LONG CLEAR plastic tube to siphon. (long clear prevents diesel mouth wash)
I bought a Flo n' Go Duramax Gas Caddy and plan on putting it in the FEL to lift it for gravity drain.
/edit - I suppose I could use the FEL to lift a 5 gallon can.
/edit 2 - here's the FEL Facilitated Fueling (FFF)
Well I guess of to hf it is..... like that is a surprise. Thanks all.
/ Fuel Transfer Pump #15
If you have any kind of usage, the hand pump gets tiring pumping from a 55 gallon drum. So...... I bought the cheapest 12v pump from TSC many years ago and it does the trick. I have an old dedicated trailer with 3ea. 55 gallon drums and this pump with battery. When the tanks get empty I hook to my pu and go to town and fill up. 3 at 50 gal of diesel (leave space for expansion) puts you under the DOT Has Mat Plackard posting requirement.
I don稚 go through enough fuel to warrant a 55 gal drum. A couple 5 gal cans is sufficient.
One of the things I dislike about my tractor is the fuel fill is in the center of the hood cowel. With these epa mandated fuel cans it is just a pain in the ***.
I go through 5 gallons or less a week in the mowing season. Less in winter.
So a $10 pump is All I need. Frankly I though they would be way more.
/ Fuel Transfer Pump #17
Let us know how that little HF pump works for you. I picked one up a few weeks ago out of curiosity, but haven't tried it yet for anything.
Since your fill port is on the hood, I'm wondering if it will have enough head to pump that high from a can on the ground. :scratchchin:
/ Fuel Transfer Pump #18
This is what I use. Battery Powered Diesel Pump
Got mine a little cheaper off ebay. It has worked out great for me. I store fuel in two 55 gallon drums.
I値l report back. No time to get out there today. If not enough head I suppose I can throw the can in the FEL and lift it.
Lower back pain is no joke. There are days lifting 5 pounds is a no go. Thankfully with exercise those are getting fewer.
/ Fuel Transfer Pump #20
FWIW, I purchased one of these pumps from Harbor Freight five or six years ago and it gets lots of use filling up the tractor and side-by-side. I extended the feed line with a smaller diameter hose that has an easier time getting down the filler neck of my truck's fuel tank. I also extended the battery leads so that the pump can sit right at the filler door on the truck while the leads reach up to the battery under the hood. Yeah, I'm paying a little more for taxed Diesel, but I don't use that much and I don't ever have to hassle with lifting cans and such.
Diesel Transfer Pump - Save on this 12 Volt Transfer Pump
