Mowing Kubuto ZD28 Loss of Power
   / Kubuto ZD28 Loss of Power #1
freycorm
Kubota ZD 28
I own a 2004 Kubota ZD 28 (diesel with 72" deck) zero turn mower. Mower runs fine at first, but as it heats up, loss of power is experienced. When it happens, it smells like it is running rich (diesel smell). We have changed filters, cleaned (and changed) fuel lines, dropped and cleaned fuel tank, etc. We have also checked all valves and compression and all are fine. We have also watched the fuel filters when we experience the loss of power, and the filters have normal fuel levels running through them. Mechanics that have done this work for us are at a loss.....can't figure out what else it could be. Any suggestions?
we changed the air filter, and no restrictions observed on the intake
Ok - thanks for the response. It only has the loss of power after mowing for a period of time.....basically after engine is hot. I can mow for 45 minutes or so and it runs perfect, then all of the sudden it starts running bad and loss of power. Does it every time.
   / Kubuto ZD28 Loss of Power #6
Well that indicates something else that is heat related. Something opening up from expansion.
   / Kubuto ZD28 Loss of Power #7
How about the muffler? Anything loose in it? Also could be a sticking injector when it get hot. I run some injector cleaner in my ZD21 about every 3rd tank( run red dye diesel)
   / Kubuto ZD28 Loss of Power #9
Sounds a bit like vapor locking... Does your fuel line lay close to the engine block, or near the exhaust?
Another thought, maybe some trash is floating around in your fuel tank and finally gets sucked down close to the outlet, causing somewhat of a fuel starvation or restriction.
   / Kubuto ZD28 Loss of Power #10
How many hours on the machine?
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A56435)
2016 RAM 5500...
2020 DRAGON ESP...
2016 Morbark Chipper (A55787)
2016 Morbark...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
2011 Atlas Copco XAS 375JD6 Towable Air Compressor (A55973)
2011 Atlas Copco...
