simplicity ride on mower problem
/ simplicity ride on mower problem #1
gravelman
NH
Kubota 2650
gravelman here..not sure how small a "tractor" we are allowed to talk about here but i have a 2014 Simplicity ride on mower with a Briggs and Stratton 18 hp engine. It will start and run but only for a short time. I changed fuel filter, same thing. I see a small black plastic item, must be fuel pump?? with 3 lines in/out of it. Could it be this?? Any guidance much appreciated.
/ simplicity ride on mower problem #2
If the oil dip stick doesn't seal the fuel pump can't pump because it rely s on crankcase pulse.
You might check the tank vent system too.
They used to just have a vent but now they have to capture emissions.
ok i will look at that...thanks very much
/ simplicity ride on mower problem #4
That sounds like a vacuum fuel pump. Fuel in, fuel out, and vacuum line makes three.
/ simplicity ride on mower problem #5
Before just replacing the fuel pump, make up a temporary fuel supply. A mustard plastic bottle or similar with a narrrow spout the rubber gas line to the carb will slide onto. Put gas in the mustard bottle, turn it upside down so gas flows out of bottle and into carb.
If the engine now runs OK you should replace fuel pump. (3 hoses)
Dave M7040
/ simplicity ride on mower problem #6
Dave M7040
Just make sure its higher than the carb. That's how I found out my fuel pump was bad.... the tractor ran fine as long as the fuel level was higher than the carb. Once it dropped lower than the level of the carb, the engine would sputter and die.
all good suggestions..will keep you all posted...
CHANDLER 10' STAINLESS STEEL FERTILIZER SPREADER (A64277)
CHANDLER 10'...
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
Power command Transfer Switch (A62679)
Power command...
2001 KENWORTH W900 72" STUDIO SLEEPER (A62613)
2001 KENWORTH W900...
2015 PETERBILT 567 TANDEM AXLE DAY CAB (A66091)
2015 PETERBILT 567...
LS MT225E (A64126)
LS MT225E (A64126)
