What Are Plunger Extensions on New Holland 311 Baler For
   / What Are Plunger Extensions on New Holland 311 Baler For #1
Blueacre
Niagara Falls, New York
Case 580 SL and IH 574
I just bought a New Holland 311 Baler at an auction. I was checking the condition of the roller bearings on the plunger and noticed there were 4 sets of holes on the face of the plunger in the vertical bars on either side of the needle opening but nothing in them. I checked the New Holland parts list on line and it shows 4 Plunger Extrensions mount in these holes with carraige bolts - look like straight pieces of steel flat bar with a hole in each end. I also saw other listings on line for a what is called a plunger extension kit with 4 of the bars and 8 carraige bolts to mount the bars.
Wondering why the bars are not installed on this baler - Is it an optional attachment that is not always used ? If an option under what conditions would it be necessary to install these extensions ? If the extensions are required does anyone have a 311 baler and could check and see if they are just straight steel flat bar and if it is what size - thickness x width x overall length.
thanks in advance for any help
Gary
   / What Are Plunger Extensions on New Holland 311 Baler For #2
I presume PH extensions on NH small sq baler are required for same reason as on a JD small sq baler reason being when baling spongy crops such as wheat/oat/barley stalks the PH extensions pushes/holds stalks farther away from needles giving knotter just a little more room/time to complete knot/tie
Thanks for the reply Tx Jim - I figured it might be a reason like that but wasnt sure and couldnt find any info on internet. I have the operator manual but no mention of them there - I only bale hay so if that is what they are for I probably dont need them.
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2011 GMC Acadia SLE SUV (A53424)
2011 GMC Acadia...
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
2010 Nissan Rogue SUV (A53424)
2010 Nissan Rogue...
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
