Pros and Cons of using Landscape Fabric?
   / Pros and Cons of using Landscape Fabric? #11
I've had good luck with landscape fabric. As noted, if you put mulch on it, weeds will appear but be easier to pull. I've had better luck with stone. 3 or 4 inches of stone over the fabric pretty much stops everything. I have areas I did about 8 years ago and so far, no weeds at all.
Whatever you do, do not use black plastic. The previous owner of my place put down black plastic and covered it with mulch. I'm still finding it buried and creating a muddy mess.
   / Pros and Cons of using Landscape Fabric? #12
Irrigation ditch will collect silt which will allow weeds to grow in and through fabric. Do not use fabric in the ditch
   / Pros and Cons of using Landscape Fabric? #13
Hardly anything man made is "forever". I think landscape fabric, the good brands, do what they intend. I've used it in garden paths with shredded cedar branches as a mulch. Yes the dirt washes over it and some weeds do grow in and thru it. But I am able to maintain it rather easily by pulling or slicing a hoe between the fabric and the weed. I've also use such fabric with a rock (solid or decorative) covering it. That works to my satisfaction...e.g. where i park my equipment trailer.
But I'd doubt that using fabric in you application would be worth the cost or effort.
Cheers to finding what will work best
Mike........
P.S, How about filling in the ditch with dirt to level it up enough to mow.???
   / Pros and Cons of using Landscape Fabric? #14
When bark mulch rots, it turns to dirt. Then you have dirt over landscape fabric, the weeds root in dirt, spread their roots through the fabric, and its a lot harder to pull out VS just in dirt. I've given up on landscape fabric and just throw on an inch or two of fresh mulch ever year or two and I'm good.
The only places I use solid plastic sheeting is in an area on a slight slope where I want any rain water to percolate downhill away from my house. That works pretty good, especially if you put rocks over the plastic. Mulch tends to wash off it.
   / Pros and Cons of using Landscape Fabric? #15
Crab grass grows thru landscape fabric...
Weeds in my garden grow under it, and are now pushing it apart.
There is 120 gallons per minute of water flowing through the ditch during irrigation season.
There seems quite a variation of experience both pro and con with this landscape fabric stuff ...
   / Pros and Cons of using Landscape Fabric? #17
You can *make* landscape fabric work, like anything else, at least for a while, if you maintain it. As a former landscape designer I've pulled up more than my share of the stuff. Never installed it. I talked people out of it because these were people who wanted a *low-maintenance* solution. Most of these people find that after 1-4 years the LF system fails, i.e., there are just as many weeds as before plus a lot of ugly fabric poking out--and it's a bear to pull up at that point.
I think the point is, after the first year, you're still weeding, and almost as much as before, because weeds begin seeding themselves into the mulch, dirt, or rocks on top of the material. Pretty soon, every weed you pull disturbs the material. The fabric starts poking up, especially on the edges, which looks awful. It also begins to tear and the weeds take advantage of that. Frost-heave and heavy rains will also do a number on it. Soon, every weed you pull also requires some kind of repair to the fabric, doubling your work, and the whole thing looks like HE double-hockey-sticks.
I hope it continues to work for you, Fishhead. Sounds like you don't mind maintaining it. I still believe it's not the best solution if you want *low maintenance*.
   / Pros and Cons of using Landscape Fabric? #20
It seems like we’re mostly on the same side here. Landscape fabric is terrible. I don’t like mulch either. Rocks probably cost 5 times as much but it’s a forever project. Mulch needs it every year and no insect problems with rock.
2005 Mitsubishi Lancer ES Sedan (A55853)
2005 Mitsubishi...
1985 Miller Wildcat 350-D Welder (A51691)
1985 Miller...
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A53422)
2015 Ram 3500 4x4...
2017 Ford F-150 Crew Cab Pickup Truck with Liftgate (A55852)
2017 Ford F-150...
Swict 72" Bucket (A53316)
Swict 72" Bucket...
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
