Proofmeter cable leak - basic hydraulic pump questions
   / Proofmeter cable leak - basic hydraulic pump questions #1
bowlingd
Ford 860
I'm a newbie who's having trouble with a leak from the area where the proofmeter cable attaches to the rear of the hydraulic pump on my '55 Ford 860. It's actually leaking in two places (more quickly in the rear than forward). See link to video below.
After spending a few hours today unsuccessfully trying to fix the problem, I have some basic questions about how this all works:
Q1: From what others have said, my understanding is that this is probably engine oil?
Q2: Should there be engine oil in the rear housing of the hydraulic pump? (My current understanding is yes)
Q3: Should there be hydraulic fluid in the rear housing of the hydraulic pump? (My current understanding is no)
I replaced the gasket on the pump-side of the proofmeter housing, to no avail (actually the brand new gasket disintegrated). Then seeing that I wasn't really sure what good the gasket does anyway, I used teflon tape on the pump side of the proofmeter housing...also to no avail. I also used teflon tape on the proometer connection, but unsurprisingly this didn't help either.
Any help or basic knowledge would be appreciated! Thanks!
Video: Proofmeter leak - YouTube
   / Proofmeter cable leak - basic hydraulic pump questions #2
Should be a seal in the tach drive on the rear of the hyd pump where the cable screws too.
Is this the seal you're talking about, or something different? If it's this seal, I've tried replacing it, to no avail.
   / Proofmeter cable leak - basic hydraulic pump questions #4
There should be a seal on the rear of the pump where the tach cable attaches.
There should be no oil coming out of rear of the pump even with the tack cable unhooked.
2013 Peterbilt 367 T/A Crane Truck (A55973)
2013 Peterbilt 367...
1957 Chevrolet Bel Air - 2-Door Hardtop, Period-Correct Engine (A56435)
1957 Chevrolet Bel...
2015 GENIE S-45 TELESCOPIC BOOM LIFT (A52709)
2015 GENIE S-45...
2016 Ford F-150 4x4 Pickup Truck (A54814)
2016 Ford F-150...
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
