Adding winch to trailer
/ Adding winch to trailer #1
dwalk19
Gold Member
Addison, ny
2018 LS XG3140H TLB
Hey guys I'm thinking of afding a 8k-12k winch to my 20' trailer, just looking for advice,
1) i'd like to find a winch with wireless remote that won't break the bank
2) would bolting it through the deck boards be sufficient, probavly easiest I do have the 6" vertical L channel frame in the front edge of deck
3) what's best way to power it, add it's own battery probably and best way to keep it charged
/ Adding winch to trailer #2
If U have the large round trailer connector there usually is a live pin just for the purpose of charging batteries or provide 12VDC to the trailer.
As to fastening the winch due to the pulling power U better be well bolted/fastened to solid steel.
/ Adding winch to trailer #3
I added a 9500 lb. Superwinch ($300) to my 20' equipment trailer, and I also carry a 20K capacity snatch block.
I welded a winch mount to the trailer frame at the front edge of the deck.
I have a cable attached remote.
Made up some 22' -2GA. removable extension cables with squeeze clamps, to quickly attach to my battery under the hood.
I do not like the idea of a separate winch battery as there is no easy way to keep it charged, unless the trailer is stored where 120v power is available.
/ Adding winch to trailer #4
Harbor freight has a great 12k winch on sale for 279-299. Ill say welding on a 2” receiver then using a winch cradle that will fit in the receiver would be a good way to go about this. Also, bh raising the winch line it won’t get near the wear or damage as it would dragging over the edge of the trailer. Bolt on a battery box with a solar charger and you’re set
Brett
/ Adding winch to trailer #5
i've done the winch cradle thing. can move it to anything with a 2" receiver, front/rear of vehicles, both trailer, etc. i have a spare battery that i attach when using the winch and then put back in whatever i took it out of after i'm done.
/ Adding winch to trailer #6
I welded a 2" receiver to my car hauler trailer because I have friend the borrows it from time-to-time to retrieve collectible cars in non-running condition. He just pops his winch on and takes a good, charged battery and that's usually good enough for several pulls if needed.
As for putting a battery on the trailer or not, you can charge it from the trailer plug, but you cannot run it from the trailer plug. It pulls too many amps and will melt the wires, blow fuses, etc... put a battery isolator at the battery on the trailer so that the tow-vehicle will charge the trailer battery, but the winch load will not pull from the tow vehicle battery. It should only pull power from the battery mounted on the trailer.
That, or put in heavy gauge cables from the tow vehicle battery to the rear of the vehicle, and use power plugs to run cables to the winch on the trailer.
/ Adding winch to trailer #7
"That, or put in heavy gauge cables from the tow vehicle battery to the rear of the vehicle, and use power plugs to run cables to the winch on the trailer"
AND THEN......What to do when using a different trailer tow vehicle?
/ Adding winch to trailer #8
A small generator and a batt charger in the back of the pu will keep charging the winch batt. as you are using it.
That's my preferred method...
SR
/ Adding winch to trailer #9
As others have said, attach a receiver to the front of the trailer, buy or build a winch carrier and use a separate battery. I just use my camper battery so it gets multiple uses.
When I setup my winch I bought a used 9,000# Warn winch, built my own carrier that allowed me to pin a aluminum box that I made on top. Then I ran a wire off the trailer plug for charging the winch battery. I am careful to unplug the charging wire before using the winch though. It makes a versatile unit that can be switched from trailer to vehicle easily. I just bought a new trailer Saturday that I need to setup to accept the winch.
/ Adding winch to trailer #11
If you are worried about maintaining batteries and damage or theft, it is amazing how much you can still get done with just a hand crank boat winch. Some use a worm gear for more reduction, but I don't think those have a release for paying out line.
For a step up from that, a common modification is to remove the handle and pin or weld the nut on, and run it with a cordless drill.
/ Adding winch to trailer #12
Here is my set up on my car hauler. It get used daily. I never have an issue with the battery not being charged
/ Adding winch to trailer #14
Made a bridge mount for the front of my gooseneck so I can retain the d ring in front. I then installed a high amp quick connect to hook an extra battery to and also made cables with jumper cable ends.
Thanks guys for all the ideas, now just gotta find time to get it done
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A65053)
2018 GENIE GTH-636...
Ditch Witch 6510 DD Trencher 4x4 (A62613)
Ditch Witch 6510...
2016 Ford Escape SUV (A61569)
2016 Ford Escape...
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
2007 CHEVY C4500 WESTERN HAULER (A65643)
2007 CHEVY C4500...
