1 or 2 rear remotes
/ 1 or 2 rear remotes #1
skindaddy
L2501
i guess im still not sure if i should get 1 or 2 rear remotes!
can you do anything with 1? or best to get 2
at this moment i dont have a use for them, but someday hope to gain attachments.
also im still confused would it be a good idea if i got 2 remotes to get both float? not sure about if i would use the detent, but all is in the air right now.
thanks for your time
/ 1 or 2 rear remotes #2
When its your money, it's easy to say "More is better!"
...or better to have and not need than need and not have.
My tractor came with one. I never used it.
Then I wanted a rear blade with hydraulic "tilt" and "rotate". Needed 2 valves.
It was then I'd wish I had just bought it with 2 rear valves when new.
It was $800+ just for the kit to add another rear valve, and I installed it myself. (Had to remove fender, (suppose to remove tire, etc..).
I now wish I had 3 remotes so I could add a hydraulic "offset" cyclinder to my blade, or a hydraulic top link, etc...(More is better!)
p.s. I also wish I had extendable lift arms on the 3 point hitch.
/ 1 or 2 rear remotes #3
I requested two when I ordered my B2650 and the dealer said the second remote has the float function.
/ 1 or 2 rear remotes #4
One means Top or Tilt, but not both.
Two means Top and Tilt, nothing else.
Three means TNT and one other function (changing the angle of a grader blade for example)..
What's the cost difference between 1, 2 and 3? A valve with more spools, some more fittings, some more hoses, and more QD's on the back. In other words, it shouldn't be all that more expensive to go from 1 to 2 or 2 to 3.
I chose 3 RR because I knew I'd regret it someday if I didn't. The slightly extra money was worth not having the regret or frustration of not doing it right the first time.
For you're rear QD's, I highly recommend double acting QDs being held by the body. These can then be connected by simply pushing and disconnected by simply pulling. This last feature means the QDs will disconnect on their own if you fail to disconnect them when you dismount the implement.
LD1 has more info about these QDs, I copied his RR design.
/ 1 or 2 rear remotes #5
Get 2 remotes (4 ports - 2 levers ) unless your running a big hay or farming operation 2 will be sufficient and likely you'll never use the second one.
/ 1 or 2 rear remotes #6
My 75hp tractor came with 2, I added the factory 3rd valve and since then have added a double diverter system so that I now have 5 sets of rear remotes. My 32hp tractor only had a single rear remote available witch was an option that I ordered with the tractor. I added 2 more and have since removed the 2 manual added valves and added a triple diverter system so that I now have a total of 4 rear remotes. :cool:
I recommend that you get all 3 sets of rear remotes if available, 2 with float if available. You didn't mention what tractor it is that you are getting. All the different manufacturers don't offer the same number or types of valves.
Good luck with your decision and I hope that it works out well for you. ;)
man i knew i would leave that out looking at L2501 HST.
idk if i would ever need 3 remotes let alone afford something that would use it lol.
thanks for the help everyone, hopefully they are nice and intergrated if installed by dealer! do i need to demand they are kubota brand so they dont try some cobble job? if thats a thing
/ 1 or 2 rear remotes #8
I have 2 and wish I had 5.
I'd go with as many as you can add and afford.
/ 1 or 2 rear remotes #9
If getting the factory Kubota sets, bring up and get in writing what they will do if the valves end up leaking internally allowing cylinders to drift. This has been a problem the last few years and depending on your dealer if the problem ever gets resolved or even attempted to get resolved.
Just a heads up. ;)
/ 1 or 2 rear remotes #11
A skidding clamp with a rotate would be nice. Add in a hydraulic 3rd link, and there would be 3 remotes.
/ 1 or 2 rear remotes #12
My Mahindra came standard with one and allowed up to 3. I bought it with three. One for hydraulic top link and two for a snowblower (chute rotation and deflector).
Summit Hydraulics offers all kinds of multiplier kits but they aren't the same as having an actual extra remote.
ok that would bring up another question, i do want a 3rd function, which was told on here get from fit rite- - but does that 3rd function have to be added into rear remotes? i thought it wasnt!
Just a heads up. ;)
well that dont help with decisions! a few said to go with factory if available so its more incorporated into machine instead of having to bolt on somewhere, which is why i would want from kubota, but if there worthless it'd be a huge hit i cant afford
/ 1 or 2 rear remotes #15
First, I no longer am doing complete 3rd function kits, valve, couplers and control grip only. Mounts and hoses and associated fittings to be supplied by others.
Second, ask-tell the dealer that you have heard that the rear remote valves can be problematic, (internal leakage) and what-how would they deal with that if it were to occur with yours.
Depending on the answer should tell you what kind of a dealer they are. If they say that they would fix it under warranty, get it specifically in print, as in where does the warranty show that that type of problem is covered. This all sounds over kill, but it seems to not be very clear as to how or when this would be covered, and this IS NOT just a Kubota problem.
You can get better valves for less money than the Kubota units, but they are not going to be integrated into the tractor as the factory Kubota units are.
Pictures are just an example of a 3rd party installation on a Mahindra 1526 which is the same size machine as the 2501 that you are looking at.
mtnviewranch,
thank you for your suggestions.
could you point me towards a way or company to do the third function? i'm sure you could buy parts from all over, but with being inexperienced it would def. be easier to try to get bulk from one place or to find a kit of some kind.
*edit
ok wait i just reread it your saying i could get everything from you but the hoses/fittings and just fab up my own mounts ?
/ 1 or 2 rear remotes #17
I have one rear remote that runs my hydraulic top link. Its really nice to use with my big 'ol heavy Rhino 950 rear blade, Land Pride GS2584(LPGS), Bush Hog RO720(ROBB) - - you get the idea. The only thing I could use additional rear remotes for would be the Rhino rear blade. The blade can be fitted with hydraulic tilt and angle as well as "curl" with the top link. If a person so desired - you could get more hydraulic fluid flowing than blood in the human body.
The hydraulic top link is a fantastic addition. Saves a LOT of time, frustration and allows ground engagement implements to be used at their optimum.
I have yet to find a need beyond the one rear remote. Actually - to state it better - I have yet to find an implement, that I need, that would require more than one rear remote.
/ 1 or 2 rear remotes #18
I had triple rear remotes installed on my 2008 Mahindra 5525 when I bought it new. Dealer's design. $750. A bargain price compared to some others that I've seen.
Good luck
/ 1 or 2 rear remotes #19
mtnviewranch,
*edit
Correct, best to fill out the contact page on my website and we can go from there.
/ 1 or 2 rear remotes #20
PRESURE WASHER TRAILER (A65643)
PRESURE WASHER...
Landhero Backpack Leaf Blower (A66408)
Landhero Backpack...
Skid Steer 3 Point Plate (A65640)
Skid Steer 3 Point...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
(4) Rims (A65640)
(4) Rims (A65640)
2005 Lexus ES 330 Sedan (A64194)
2005 Lexus ES 330...
