3 PH side link cylinder sources...
/ 3 PH side link cylinder sources... #1
/pine
Super Star Member
Can anyone suggest online resources for wide varieties of hydraulic cylinders other than Surplus Center???
I'm wanting a new (bare bones) cylinder that I can add custom link ends to...
Looking for a 2.5" to 3" bore with a minimum of 4"stroke...retracted length should be 13" or less...
Want a welded cylinder for easy fabrication...I'm afraid tie rod cylinders use cast ends...I need to be able to MIG custom pin ends to the cylinder...
I have scoured the Surplus Center site and want to make sure there is not a better more ready applicable cylinder available...I do not want to buy "unused (old) inventory"...as it is not uncommon for rod end seals to dry out and start leaking after a very short time...
I do not want a generic pre-fabricated side link to start with...just too much $$
/ 3 PH side link cylinder sources... #2
I'm not sure you will be able to find a double acting cylinder in the size range that you need with no ends. :no: Probably going to have to get a welded unit and cut off the ends. I recommend that you get a tube type welded unit and go from there. Maybe Bailey?
What tractor are you building this for? Are you going to build it to get single side tilt, or to tilt in both directions equally?
B1700 (basically same as 2100, 2400)
Yeah I don't mind cutting off whatever is on a cylinder...just have to work out the lengths...I'm replacing a leaking cylinder I made about about 8 years ago out of a surplus cylinder that I have no information on...
No thanks...I have a leaking top link I got from them and they want something like $5 for one thin o-ring and another $5 to mail it to me...also the dpcv messed up and started rattling...if it's hay season it would take a month to get a part...
/ 3 PH side link cylinder sources... #5
I use a 4" stroke unit and with a small modification to the lower clevis, Then you have a unit that gets you an equal amount of tilt angle to each side.
Why would you use a 2 1/2" or 3" dia unit? 2" is more than enough for that tractor. I'm not sure that a 3" dia unit would even fit? :confused3:
/ 3 PH side link cylinder sources... #6
/ 3 PH side link cylinder sources... #7
NCM_0824.JPGFound a picture of my tilt cylinder.
/ 3 PH side link cylinder sources... #8
Try bailey, I order stuff from them a lot.
Shopping
Thanks for the replies and advice...not sure why I was looking for such a large bore cyl...likely because that is what I had on hand that I could make work 8 years ago when I first fabbed a tilt cyl,
...It was a 4" stroke and I did set it half extended when I set the length to what the solid link was...gave me plenty of tilt in both directions...
I will expand my search now to include down to 2" bore cylinders...thanks again for the advice and the links to the sources.
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
Unused 2023 USA Attachments Quick Coupler Excavator Attachment (A66734)
Unused 2023 USA...
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
2009 WESTERN STAR 4900 SF WINCH TRUCK (A67714)
2009 WESTERN STAR...
213324 (A64279)
213324 (A64279)
LOOK! (A63111)
LOOK! (A63111)
