JD 5210 hot starting
/ JD 5210 hot starting #1
bagvette
jd 5210
hi folks,
have a 5210 that starts fine when cold, but after running an hour or more, it won't restart till it cools down couple hours later?
will crank over when hot, but not start. i get the feeling it isn't getting enough fuel. didn't have this problem till i had it "tuned up" with new filters etc from the dealer few months ago.
runs fine after starting. has new battery and was doing this before replacing the battery.
thoughts?
bruce
/ JD 5210 hot starting #2
I'd pay the dealer a visit and lay it in their lap. just sayin...
:welcome: to TBN
Someone else may have a better answer... ;)
/ JD 5210 hot starting #3
Welcome to TBN
How hrs are showing on speed/hr meter? Do you hear fuel control solenoid clicking when engine is at operating temp. when ign switch is turned to on position?
/ JD 5210 hot starting #4
IIRCC these have a cold system that advances the injection pump. Maybe the injection pump is "stuck" in the cold start position??
/ JD 5210 hot starting #5
Do not have the answer, but here is what I would try: 1) Make sure the fuel filter ring is tight. 2) Make sure the water separator on the bottom of the fuel filter is tight. 3) Next time this happens, just to test take the fuel cap off, as the tank maybe not be venting correctly. 4) As mention before make sure you are getting power to the fuel solenoid. See if you can hear it clicking. Must admit I can never hear my clicking on my 5210.
Welcome to TBN
about 1100 hours. i haven't noticed any clicking.
yes will check this out, but working this weekend so won't be till next weekend that i can run it. seems like the 5210 had issues with the cold starting system. fires up fine when cold, not so much when hot.
/ JD 5210 hot starting #8
You can disconnect the CSD {cold start devise} on the inj. pump w/ no ill effects.. it just unplugs..
AND there IS a very big problem w/ the temp sensor that its connected to.. they short out & the tractor keep blowing the start fuse..
VERY WELL documented..
/ JD 5210 hot starting #9
Look into the temp sensor thing and maybe unplug to try. There could be a problem with it and it's purpose is to alter timing in cold weather. I suppose it could malfunction.
/ JD 5210 hot starting #10
Its only active ON START UP or "supposed to be"..
The sensor tell it when to come on {cold} but w/ the documented problems WITH THE SENSOR, it would be worth a shot..
& only takes a second to unplug.
/ JD 5210 hot starting #11
What I was saying in post #4, it MAY be the problem???
2013 HERCULES ALUMINUM KILL TRAILER (A60736)
2013 HERCULES...
2020 Hino 195 20ft. Electric Box Truck (A59230)
2020 Hino 195...
New/Unused 2in Ratchet Strap (A61166)
New/Unused 2in...
DRESSER GALION 712 TANDEM ROLLER (A62129)
DRESSER GALION 712...
2006 ISUZU NPR BOX TRUCK (A59908)
2006 ISUZU NPR BOX...
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
