Buying a 2018 L3301 DT Package deal
/ Buying a 2018 L3301 DT Package deal #1
Manshoon
Spokane, WA
2018 Kubota L3901 DT.
So, I tried the first time with a Branson and struck out big time with a HST 2800 4x4 Package that had major HST issues that took a little over 7 months to fix. No love from the selling dealership, not that I was expecting any, but none just the same.
So for the second time in my life I am going out and buying another package deal, but this time I am going Kubota Orange. The deal I made was for as L3301 DT with a SSQA bucket, Land Pride 60" Back Blade, LP 60" field Mower, a front remote for a grapple hook up, sitting on a 20' dual axle trailer with brakes on 1 axle for 24500.
I am going the 0% route with the Kubota Insurance. I am going to check into the insurance though, as they don't seem to cover allot. I am pretty stoked to go pick it up whenever I get the call that it's ready to go. I would like to know that I am getting the best deal I could be anywhere else. Opinions would be greatly appreciated.
/ Buying a 2018 L3301 DT Package deal #2
I am a little confused, the field mower has a quick attach ? As for package deals, I never had the occasion to purchase one, but by design, they are assembled to simplify the purchasing process, consolidate implements, and most of all, be competitively priced. Do you need a trailer? Sorry, not familiar w/ smaller Kubotas, it does have a front driving axle? Tires loaded? Grill Guard?
You might ask the dealer how many of these packages he has sold? Give you an idea of popularity? I did purchase the Kubota ins w/ my tractor, never used it so no experience w/ coverage, do they insure the trailer as well? The towing vehicle usually insures, by default, the trailer as well. Maybe they provide comprehensive for the trailer (fire and theft, vandalism)
Good points, yes I better make sure we are on the same page with the 4x4 option, grill guard ect. As for the Quick change bucket or as I hear the standard is SSQA, it will have that, also the remote for a front grapple implement. Trailer is a must for me as I am traveling to pick it up and like a way to get it into a dealership in case of breakdown ect.. I am under the impression and I will verify with a phone call tomorrow that the trailer is made by City trailers. Comes with the Bulldog hitch ect with brakes on only 1 axle, but that isn't a problem for me to add another provided the Hub assembly is user friendly.
/ Buying a 2018 L3301 DT Package deal #4
Could you explain this? In my understanding KTAC coveres just about everything shy of a nuclear alien invastion zombie apocalypse
/ Buying a 2018 L3301 DT Package deal #5
Omega Woods - that's the extent of the coverage I had with KTAC. Just about everything except zombie apocalypse.
/ Buying a 2018 L3301 DT Package deal #6
A lot of those package deals put together the cheapest equipment to make it seem like you’re getting a lot for a little.
/ Buying a 2018 L3301 DT Package deal #7
I was looking at the same machine last fall until I realized the night before I was going to buy that the DT doesn't have a live PTO; which is almost a necessity with the rotary mower as well as a tiller and a few other PTO driven implements. To get that you either need to go into a 3901, or an HST. I ended up with a slightly used 2015 3301HST, but wish that I had sprung for a new 3901 DT instead.
/ Buying a 2018 L3301 DT Package deal #8
One way to deal with the non-live PTO would be to add a one way clutch adaptor:
SpeeCo Over-Running Clutch Adapter, Male Spline 1-3/8 in. x 6 at Tractor Supply Co.
Unless you're going to be hauling the tractor to work sites the trailer's not going to get used often. Especially if you do your own routine maintenance (it's pretty simple, tractors are less complex than modern trucks). My last tractor never went to the dealer and the current one hasn't yet either. It'd be cheaper to rent a trailer when you need it.
/ Buying a 2018 L3301 DT Package deal #9
My thoughts mirror ericm's... most often, a dealer will deliver a new tractor as part of the deal, and it is fairly likely you will not need to take that tractor anywhere other than your own property. Service and maintenance is best done by you, both for cost and for care reasons, and in owning three Kubotas, all bought used, none has ever needed to go anywhere beyond my simple shop. Of course, you may want a trailer for other reasons...
/ Buying a 2018 L3301 DT Package deal #10
Good call...agree on that point. Ask seller if you need over running clutch to operate rotary mower with DT on that model and see what he says.
Yes, I opted to go with the 3901 DT instead because of that very reason . Instead of breaking what little bit that is offered with the after market parts/adapter. The increase in $ for the extra 6 HP and the live PTO option was $1500.
So in the end, it was 26k for the L3901DT with Quick attach bucket, 20 ft 7k Lamar Trailer, LP 5' cutter, LP 5' Box Blade, Third function mounted to the front, Block Heater, and 0% for 60 months.
/ Buying a 2018 L3301 DT Package deal #15
That is an overrunning clutch so that when you stop the implement doesn't keep running and pushing the tractor. This is included in the tractor trans.
Live PTO means power keeps going to the implement when you push in the clutch, to say stop or turn, slow down, etc. My last kubota had it and it's OK, but not ideal. A brush hog has a LOT of rotating mass so will keep going, but you do have to 'start' it moving more often - more wear on parts. I doubt you'll wear anything out in your lifetime though.
I found it a bigger problem with the MMM as it has less mass and would spin down nearly instantly. Here there is more wear on the belt(s).
New tractor (kioti ck3510hst) had live PTO and it's great.
2014 Lamar Trailer (A55973)
2014 Lamar Trailer...
gps trailers (A56859)
2021 Deere 75G (A60462)
2021 Deere 75G...
2017 Volvo VNL Truck, VIN # 4V4NC9EH8HN976739 (A61568)
2017 Volvo VNL...
HYUNDAI HL955 WHEEL LOADER (A62129)
HYUNDAI HL955...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A60352)
2015 SkyJack SJ86T...
