MT372 with Haban deck
/ MT372 with Haban deck #1
lightleader
Ferrari, Mitsubishi, deering, JD
/ MT372 with Haban deck #2
Here is half the manual but it does have the IPB and original part numbers for the deck.
Right, I have the manual, it gives factory part numbers. So what is the actual bearing? 6102, 6202 etc. I have a ton of bearings in stock, but don't want to tear it down and find i need to order something else. Then i have a dead unit laying here untill parts arrive. Just hoping someone out there has worked on one of these before. (P.S. I don't pay factory prices for parts, try to find better alternative solutions for my customers.) Example, factory spot welded idler. Drill out spot welds to say, 1/4", separate pulley halves, drive out old bearing, replace and reassemble pulley using 1/4" bolts w/shakeproof nuts. Now you have a repairable part that will last a lifetime and is only $1.50 to repair instead of $15.
Thanks for the quick response
Haban front deck support pan. Scraped off 3" dirt, grease & ?? Sanded rust off and gave it a good coat of bed liner20180602_163334.jpeg
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
213137 (A64276)
213137 (A64276)
UNUSED WOLVERINE HYD TILLER (A64281)
UNUSED WOLVERINE...
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
