Landscape rake
/ Landscape rake #1
coolbrze
Gold Member
VA
Kubota MX5800
I've got a Kubota MX5800HST & am looking at purchasing another landscape rake (the 6'er I have for my other tractors is too small). The max width of my MX5800 is the rear tires & they're ~79" wide. It will be used mainly for raking my driveway that's a little over 1/2 mile long but also for raking some trails & food plots I've got going through the woods where there are sticks, rocks, leaves, etc. Should I go w/ a 7' or 8' wide rake & who manufactures a good solid rake? Also pros & cons to gauge wheels?
/ Landscape rake #2
York rake is a good one. For length, make sure when the rake is at full angle it is at least as wide as the tires. You should also consider adding a drop down blade with it and the scarifier.
/ Landscape rake #3
Rhino builds a good rake you can get one with hydraulic angle and tilt if you have rear remotes but my manual blade is fine for me
/ Landscape rake #4
Since your tractor is already close 7 ft wide, seems at least an 8ft rake is needed. As far as gauge wheels, I wouldn't be without them. That and a flexible link in the top link. Makes for some fine grading control.:drink:
/ Landscape rake #5
Go with an eight foot rake.
Everythingattachments.com makes excellent Landscape Rakes. Mine is 72", purchased in May 2013; $797 + $299 gauge wheels = $1,096. I would unhesitatingly repeat the purchase.
Landscape Rake | York Rake For Compact and Full Size Tractors
York-Modern is another top producer.
Shop York : York Modern
WEIGHT PER UNIT OF WIDTH IS YOUR FRIEND IN GROUND CONTACT WORK.
Do I Need Caster Wheels on my York Rake?
Yes, if you want professional results!
York Modern Caster Wheels
As with any three-point hitch implement it is virtually impossible for it follow the grade relying solely on the three-point hitch of the tractor. Trying to follow the grade by constantly adjusting the three-point hitch can be tedious, if not impossible. They are just not designed to do this. Using this method also results in the implement doing the exact opposite of the tractors front wheels. As the wheels go in a hole, the implement comes off the ground and as they ride over a high spot, the implement digs in.
You have to be pretty quick on the three-point hitch lever to avoid this. Using an implement with caster wheels allows it 吐loat independently behind the tractor while following the contour of the ground. This is particularly important when you get to the raking stage of your site work. The best raking results will be achieved with the rake angled and the caster wheels properly adjusted. When raking you want to adjust the caster wheels in the following manner. With the rake angled, you want the caster wheel closest to the tractor higher (off the ground); this allows it to penetrate a little more. The caster wheel farthest from the tractor should raise the rake so it is barely touching the ground. The difference in wheel height only needs to be about an inch, more if the soil is really soft and you want to screen more material. This adjustment allows the end of the rake closest to the tractor to dig a little harder than the end further from the tractor. This increases the vibrating action of the rake teeth improving the rakes screening action as the material moves across the front of the rake.
Rocks and debris will move into a windrow and the pulverized soil will pass between the rake teeth. Remember too, the faster you can go the better the vibrating action will be. The resulting screening action from a properly adjusted pair of caster wheels produces an ideal finished surface, ready for seeding or sod. Caster wheels are also essential for beach cleaning work, as they will help keep the rake from digging in too deeply.
Give York a call to learn more about equipping your York Rake
with caster wheels. 1-800-643-YORK (9675)
When you have gauge wheels and the rake is set on an angle, the outboard gauge wheel protrude ~~~way out there~~~ limiting maneuverability.
I was clearing an acre lot today. A Ratchet Rake is far better for woodland and trail work and for piling debris than a Landscape Rake. A Ratchet Rake also can move dirt 20' to 30' much like a Box Blade. I use my Ratchet Rake far more than my ETA Landscape Rake, but I do not need to grade a long driveway.
/ Landscape rake #6
I just bought a everything attachments 8 ft rake and love it, the tine bar is by far the best design for a rake, I wouldn’t go with anything smaller. IMG_3134.JPGIMG_3137.JPG
/ Landscape rake #7
8' would work the best even better when putting on the finishing touches at 45 degree angle,gauge wheels will do smooth easier finish also...drop down grader blade :thumbsup: its going to cost bunch $$$'s but worth every coin tho.
/ Landscape rake #8
+1 on the York rake.
I bought a 7' unit for use behind my old L3430HST. I also invested in a T&T kit which more than doubles the usefulness of the rake. I maintain 1.25 miles of gravel road and several 400+ foot driveways. The T&T allows me to clean the ditches and put a good crown on the road surface. IMO, gauge wheels are a must for maintaining a smooth even surface.
At full angle, the 7' York is about the same width as the track of my new MX5800HST with R4 tires. Were I buying a rake for this tractor now, I'd go with an 8' unit.
Initially, when I bought the MX, I was going to sell the 7' York and get an 8' model. Instead, for a variety of reasons, I bought a second tractor. I picked up an L6060HST on sale last spring. The L6060 has a narrower track than the MX and works well with the 7' York rake. As a bonus, the T&T kit I bought for my old L3430 does not fit the MX but works fine on the L6060.
/ Landscape rake
Dang it. 8' seems huge (to me) & I want to lean towards the 7'er. But... I'll listen to y'all & at least go look at a few 1st :) In terms of raking the driveway, do you recommend raking w/ the rake angled in so the loose substrate creates a higher crown on the DW?
/ Landscape rake
So after more research, this is prob. the LR I'm going to purchase. What do y'all think of it? Also... are the gauge wheels a put on & leave on kind of thing or are they simple to remove should I want to?
Everything Attachments Landscape Rake, Root Rake
/ Landscape rake #11
I have a MX5100 and an Everything Attachment 8' rake and am VERY pleased with it. I did not get guide wheels because they mentioned you cant spin it around with the wheels on. I do almost a mile of gravel road monthly and spin the rake "backwards" to final drag it so this would be a bit of pain for me.
/ Landscape rake #12
This is without a doubt one of the better landscape rakes available today. BUT, be sure to request that you want it to have offset capability. :thumbsup:
/ Landscape rake #13
The wheel kit bolts on, each wheel bar is held on with two bolts.
Then the wheels are adjustable with stop collars and pinch bolts, you could remove just the wheels completely or flip them over by removing the pinch bolt and collar.
I bought the 8’ but upgraded to one with offset option, have used it a few times so far and been very pleased. IMG_0245.JPGIMG_3134.JPGIMG_3159.JPG
/ Landscape rake
I bought the 8’ but upgraded to one with offset option, have used it a few times so far and been very pleased. View attachment 556249View attachment 556250View attachment 556251
I assume the offset capability is what your 2nd pic shows? Is that standard on the EA V3 severe extreme landscape rakes?
/ Landscape rake
Another question... if I get the EA LR w/ offset option, do you still recommend an 8' rake for my MX5800 or should I go 7'?
/ Landscape rake #16
You still want the 8 footer. Offset feature is typically used for ditch clean out or when operating close to a building or wall. Keep in mind that an 8' rake angled at 35* is only about 78" wide. 45* puts you at 67".
/ Landscape rake #17
It’s a little over 300 dollar option on that rake.
/ Landscape rake
Update: finally got my EA landscape rake a few days ago. I opted for the 8' offset version like some of you recommended. Definitely a good call on the width, I would have been happy w/ the 7' but I wouldn't have known what I was missing out on. It was worth the wait, only used it for an hour so far but it's one heckuva rake! Much better than the other lighter duty rakes I've had. Highly recommend!
/ Landscape rake #19
Ordered the 8' w/offset & wheels last week. With my new TnT it'll be very useful landscaping the new home site.
/ Landscape rake
Hey Code - you spin it backwards then drive fwd? If so, what does that do, just fine smooth it?
John Deere 630 (A64119)
John Deere 630...
2021 Chevrolet Silverado 2500HD 4x4 Crew Cab Pickup Truck (A61573)
2021 Chevrolet...
2018 CATERPILLAR 320GC EXCAVATOR (A60429)
2018 CATERPILLAR...
2011 Isuzu NRR Dovetail Flatbed Truck (A61573)
2011 Isuzu NRR...
2016 VOLVO EC250EL EXCAVATOR (A62129)
2016 VOLVO EC250EL...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
