Good morning!!!!
   / Good morning!!!! #76,831
Glad to hear it’s not Worse, Randy.
   / Good morning!!!! #76,832
We are pretty much out of harm’s way. No acid rain or ash as the winds have been favorable. Lady at PO was telling me yesterday they disconnected their catchment, they live in Mountain View and not so fortunate. She is concerned that if protracted they might run out of water.
   / Good morning!!!! #76,833
So my first thought seeing the cut down fence was where to put the cutoff portion.
Looks very nice
   / Good morning!!!! #76,834
TxDon congrats on your sale hope the move proves successful for you Whipper and your wife and family
   / Good morning!!!! #76,835
LS nice looking place you have mine looks like we live in a tropical rain forest
Randy hope your SIL gets the attention needed and the problem corrected
Thomas sounds like easy chair living to me
   / Good morning!!!! #76,836
Finally got my chipper ready!
We had it assembled two weeks ago...but with the rain and my hours at work...just no time to actually try it.
Anyway, works great! Had a tree top come down on the lawn just before the chipper was delivered...that was the test branches. 4 or 5 inches in diameter and the Woodmaxx just munched them right up. Makes nice chips. Getting the implement PTO drive shaft hooked to the tractor's stub shaft was a real pain though. New U-joint had to be positioned "just so" to slide it on. I have a bad back so I had to stop now and then. Of course, that u-joint will wear in soon enough.
I have a couple small (trunk 6" or so in diameter) trees to drop...plus a half dozen or so smaller diameter tress (big saplings) to take down...good job for the weekend, if weather permits. I really need to mow the field though...soon. The flail mower is greased and ready to go.
   / Good morning!!!! #76,837
Hawkeye, you mean one of these?
in my case a 1986 8199G
one of my first to the frame renovations, currently with 23hp Vanguard engine swap out, which I recommend highly.
If you have three, than you must qualify as a Gravely "nut"...:D
   / Good morning!!!! #76,838
Roy, glad it worked so well for you after all your hard work putting it together.
I learned not to rush mine and just have it feed in slowly
   / Good morning!!!! #76,839
Sweet machine
   / Good morning!!!! #76,840
I repowered one of mine that had Onan 16.5, put the 18hp engine on... the other two have Briggs so might recommend to my daughter to repower with the vanguard. I know some have put the 24hp Honda on also.
Pull Behind Wood Splitter (A57453)
Pull Behind Wood...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2009 FREIGHTLINER CASCADIA (A58214)
2009 FREIGHTLINER...
(2) MULE PLOWS & FERTILIZER DISTRIBUTORS (A52708)
(2) MULE PLOWS &...
2011 Atlas Copco XAS 375JD6 Towable Air Compressor (A55973)
2011 Atlas Copco...
2012 Chevrolet Silverado 3500 Ambulance Body VIN # 1GB3K0CL2CF118201 (A57453)
2012 Chevrolet...
