Tip for hooking up PTO shaft. Drop a dime.
   / Tip for hooking up PTO shaft. Drop a dime. #1
Jelf
Member
Redmond, WA
Kubota L35
Ever feel like you are about to push a hole into your thumb when you are trying to depress that pin far enough to slide the PTO shaft onto the tractor or equipment? Drop a dime into the thumb compartment of your glove. Now your thumb pushes on the dime and the dime pushes on the pin. Gotta love low-tech solutions.
   / Tip for hooking up PTO shaft. Drop a dime. #2
Good idea.:thumbsup:
I guess it's a function of age, but I can't come anywhere near being able to exert pressure with my fingers that I could when I was younger.
Steve
   / Tip for hooking up PTO shaft. Drop a dime. #3
Grease also helps a lot...
   / Tip for hooking up PTO shaft. Drop a dime. #4
I grease mine at the beginning of each season - a heavy coat of grease brushed in with a cheap flux brush. This makes it MUCH easier to mount up, and also makes the pin easier to push in and lock.
   / Tip for hooking up PTO shaft. Drop a dime. #5
I don't wear gloves so would I have to Superglue it to the end of my finger ???:thumbsup:
   / Tip for hooking up PTO shaft. Drop a dime. #6
Great idea. I've never thought of dropping a dime before trying this but on a few occasions I've almost dropped a duece straining so hard to hook up the PTO shaft
   / Tip for hooking up PTO shaft. Drop a dime. #8
Don't forget to sterilize the dime. Those Germs will kill ya!
   / Tip for hooking up PTO shaft. Drop a dime. #9
I tend to use a lot of silicone spray as it doesn't attract dirt and grit like heavy grease can.
   / Tip for hooking up PTO shaft. Drop a dime. #10
Between the GRUNT needed to lift the unattached end, depress the locking pin and rotate the shaft to get engagement - - YOU BET I'm going to give the dime a try, next time.
I have so much grease on the PTO stub and all over and inside the U-joint - - at times it feels like pushing puddin' into a rat hole.
UNUSED FUTURE 14' WROUGHT IRON BI-PARTING GATE (A57193)
UNUSED FUTURE 14'...
2008 MOROOKA MST-2200 VD TRACK DUMPER (A52707)
2008 MOROOKA...
2020 DRAGON ESP...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A56435)
2023 Kubota...
Kivel Quick Attach Forks (A56469)
Kivel Quick Attach...
2006 Caterpillar 315C L Hydraulic Excavator (A56857)
2006 Caterpillar...
