let's discuss the best way to mow a field...
   / let's discuss the best way to mow a field... #41
Isnt that thing used on ice?? it has nothing to do with mowing and i'm pretty sure People plowed a "land" before that machine was invented.
Nothing to do with mowing?? The idea is to cover the whole rink. Isn’t that the same principle as mowing?
   / let's discuss the best way to mow a field... #42
I guess it is but I am 51 yrs old and been in agriculture my whole life and never heard the term until this thread. Ive never seen a ice skating rink except on TV.
   / let's discuss the best way to mow a field... #43
Have you ever seen that pattern used to work a field? If so, what do you call it? If not, sometimes we can learn things from others who are in totally different fields (pun not intended).
   / let's discuss the best way to mow a field... #44
Its called laying off a round , Its been done this way in agriculture for centuries. I figure the first dude to run the ice machine probably had plowed a day or too before and actually amazed the city folk with it.
   / let's discuss the best way to mow a field... #45
I've never heard it called that. The Zamboni pattern doesn't work for moldboard plowing, but works for chisel plows, mowing, or disking.
   / let's discuss the best way to mow a field... #46
Why are we getting off topic over something so stupid.
Just because you never heard it called that before doesn't make it any less accurate of a term. So rather than spouting off "what the **** it has to do with mowing"....perhaps take this as an opportunity to learn something new.
   / let's discuss the best way to mow a field... #47
   / let's discuss the best way to mow a field... #50
I run a commercial mowing operation with my MX and 8' mower. To the tune of 300-400 acres per year, ranging from half acre lots to 30 acre fields, but averaging somewhere around 4-5 acres per job.
I have learned in 8 years of doing this, that there is no one mowing pattern that is most efficient for everything.
One job of a few acres that I do, that is roughly square, I mow around the perimeter 3 passes then start zamboni pattern. It is the FASTEST way to get the mower back into the cut. And the penalty for guessing wrong on how far to move down, isnt huge, cause at this point, after outlining the field, its maybe 300' to run across. And at 6 mph.... That takes a whoping 30-35 seconds. So if I guess wrong and my last zamboni pass is only cutting 4'.....eh....only took 30 seconds.
Another job I do is a 12 acre field. That is roughly 1200' on the long direction. So takes a few minutes to make a full length run. So rather than zamboni, I just mow down and back, similar to how one would mow their lawn with a zero turn to stripe it. Because the few extra seconds to reverse and line up for the second pass, is more than offset by the potential consequences of guessing wrong with zamboni.
Then there are just odd shaped fields that neither of those patterns will work on. On those I just continue circling the perimeter until smaller areas are naturally broken off from the larger chunk.
With a 15' mower and 5-series tractor though, it may be entirely possible to do a 180 degree turn within the width of the mower. I'd make a few passes to clear the perimeter, and mow down and back, even if it means making a wider turn at the end.
the penalty for guessing wrong on a zamboni gets worse with bigger mowers. make that final pass with a 15' mower only mowing 1' that was missed is alot worse than missing a foot with a 4' mower;)
180s like mentioned are hard on equipment but you値l just about for sure get the tires into the mower. I try to avoid hard turns plus its a lot of steering input
Brett
2009 Honda odyssey (A55788)
2009 Honda odyssey...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A55315)
2023 New Holland...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
S/N: 5D121002416 (A55787)
S/N: 5D121002416...
2017 Kenworth T400 T/A Aquatech B-15 Combination Sewer Jetter Vacuum Truck (A55852)
2017 Kenworth T400...
TEST YOUR BID BUTTON! (A58375)
TEST YOUR BID...
