MX5800 DPF regen
/ MX5800 DPF regen #1
coolbrze
Gold Member
VA
Kubota MX5800
I've read the manual twice & am still confused by the regeneration modes. Seems like there are several different options & I have no idea what to do when my MX does this... Can someone explain in english what I should do haha? Thanks!
/ MX5800 DPF regen #2
The regen process is mostly automatic and there isn't much you need to do. I've gone through about 6 regen cycles so far on my MX5800. The regen light will start to blink when the cycle is about to start. Just keep working the tractor with the RPM above 2200. I've gone through several cycles while mowing and hardly noticed. You will see some black smoke in the exhaust and notice a slight fuel smell. The cycle lasts about 10 minutes depending on what the tractor is doing.
Occasionally, the dash lamp will flash asking you to increase the rpm if the tractor is at idle or working too slowly. A couple of times, the regen started just as I was putting the tractor in the barn. You can cancel a regen cycle if necessary but don't do this more than twice. In my case, I just let the tractor do a "parked regen" by setting the brake and letting the tractor run at around 2300 RPM until the cycle completes.
It isn't really a big deal. Hope this helps.
/ MX5800 DPF regen #3
My 1st Regen was last week at 36 hours on the tractor.
It took about 2 1/2 hours.
I was using the backhoe when I started the Regen and was told not to exceed 2000 RPM for the 1st 50 hours.
I was running around 1500RPM
After watching the Regen flash for over 2 hours I kicked the RPM's up to the PTO speed and with in 15 minutes or so it was finished.
The next time I see the Regen light I will kick the RPM's up no matter what I am doing with the tractor.
The dealer tow truck driver told me that the MX series tractors need to be Parked to do the Regen.
When I did the walk threw during purchase they told me that I could work the tractor while it was going threw the Regen. It would do it automatically.
Next time I will help it by upping the RPM's myself.
/ MX5800 DPF regen #4
I have had 4 regens on my 5800. No biggie. Kick the rpms up and keep going. If the light is flashing it wants to regenerate if constant light it is regenerating. Takes 15 or 20 min
/ MX5800 DPF regen #5
The regeneration burns diesel soot off the particulate filter.
The engine needs to be running at about 2,200 rpm (2,000 rpm on HOT days) to generate sufficient heat to burn off the diesel soot.
Fuel cost is about $1.00 during stationary regeneration, which takes about sixteen minutes.
/ MX5800 DPF regen
Thanks guys, sounds simple enough, appreciate the help!
/ MX5800 DPF regen #7
Hi, Cool. Hope you are enjoying your MX. We have had only one regen on our MX in 48 hours--occurred after about 30 hours, as I recall--maybe because when we use the tractor we tend to keep the rpms up. Our regen lasted about 15 minutes, as I recall. Just be sure to get the rpms up to 2200 or slightly higher (whatever the manual says--I don't recall).
/ MX5800 DPF regen #8
Lol. Your Regen didn't take 1.5 hours. It took less than 15 minutes.
It's always good practice to read your operators manual! If you won't read the manual at least read the sticker on the left fender (can read it from the seat even). It will tell you that the flashing lights means the tractor needs to do a regen but the RPMs are too low. The tractor didn't start the regen until you increased the RPMs.
There's lots of good information information in that manual (seriously) and it's a heck of a lot more trustworthy that the delivery guy. :drink:. It will even give you the correct break-in process.
/ MX5800 DPF regen #9
The dealer informed me not to rev. the engine above 2000 RPM until after the 1st 50 hours for a proper break in.
I followed their advise until the Regen took so long.
They also informed me that the Regen would be automatic if I pushed the button when iit started flashing to allow the Regen instead of delaying it to a latter date.
I am at 45 hours now and the 50 hour break in is almost over. So after the break in I will be running the my MX5800 at a higher RPM to help the heat build up.
/ MX5800 DPF regen #10
So you understand that most of what you just wrote is incorrect? Just making sure. You have a great tractor. :thumbsup:
/ MX5800 DPF regen #11
Yes I do
New Operator error for sure.
Leaky loose hydro fittings in the Backhoe last week end and a Blown hydro hose yesterday not Operator error.
I need to work the bugs out. Hopefully soon.
And yes it is a GREAT tractor it is doing a lot more than I expected for the size.
/ MX5800 DPF regen #12
Yes I do
Ouch. Loose fittings happen (although some in the hoe can be a bit*h to get at) but a blown hose? That is crummy luck. I'd be curious to know the model of failure if you care to share...
/ MX5800 DPF regen #13
I bought an MX5800 with the BH92 Backhoe with a Hydraulic Thumb and the LA1065 FEL .I received it about 5 weeks ago I have just under 45 hours on it Digging a new Leach field for my Septic.
All rock and Big Boulders ( worse that Cobble) some of the Boulders are 3' X2' X2' that I have pulled out of the trench and the Tractor has been FANTASTIC.
Last week loose fittings inside the Backhoe Controls cover. Yesterday a blown 3/8" hose running from the main block under treadle peddle up to the FEL controls.
Nothing major just a defective hose.
I guess I will be ordering some back up hoses to have on hand if I am out in the Boone's where I can not get my tractor back to Snivilization.
The Learning curve sucks sometimes.
At least this was not a paying job like others on this Forum.
/ MX5800 DPF regen #14
Make sure to read the BH92 manual cover to cover. You will find it says not to operate rear remote or 3pt hitch while BH is connected (hydraulically). You will damage your control seals if you do.
/ MX5800 DPF regen #15
I don't think Newby is an instruction reader! :laughing: :drink:
/ MX5800 DPF regen #16
I read the Owners manual on the tractor twice but I also listen what is told to me by the dealer.
My problem is melding what is told to me and what I read together.
In this case the owners manual says to runn the tractor at a lower RPM for the first 50 hours and the dealer told me to run the tractor under 2000 RPM for the first 50 hours.
The regen said crank it up to over 2200 RPM when Regen.
Well me being brain dead I did what the Owners Manual and Dealer told me to do Run the Engine under 2000 RPM for the 1st 50 hours.
The next Regen will be well past my 1st 50 hours so I will rev it up with no hesitation.
As for post 14 I do not have any rear remotes (yet).
Thank you for the info. I will be adding them at a latter date.
Komatsu D39 PX Crawler Dozer (A61166)
Komatsu D39 PX...
2017 Bobcat T770 Compact Track Loader (A63118)
2017 Bobcat T770...
20 Yard Roll Off Dumpster (A61165)
20 Yard Roll Off...
JOHN DEERE 6700 SPRAYER TOW BAR (A62131)
JOHN DEERE 6700...
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
2014 CASE CX55B EXCAVATOR (A62129)
2014 CASE CX55B...
