Backhoe JD855 - What Backhoe other than #7?
/ JD855 - What Backhoe other than #7? #1
raceron1120
Ellsworth, MI
JD855
I have a Deere 855, would like to get a backhoe for it. Are there any alternatives to the Deere Mdl 7 that can be used on it with no alterations?
/ JD855 - What Backhoe other than #7? #2
Maybe a 3 point hitch backhoe But not recommend by the manufacture, They break the top link mount . Other than that a #7 JD backhoe, sorry I think that's it unless you want to put something together .
That's what I'm finding out - apparently there are no aftermarket hang-ons available. I've done some casual looking for a used Model 7 but they're scarce. Thanks
/ JD855 - What Backhoe other than #7? #4
I had one on my JD 770 nice little backhoe , If you find it make sure you get the sub frame with it. Most times its on the tractor and gets sold and the backhoe won't work with out it
/ JD855 - What Backhoe other than #7? #5
A New Holland 757 frame mount can be very easily modified to fit. IMG_0330.JPG
/ JD855 - What Backhoe other than #7? #7
/ JD855 - What Backhoe other than #7? #8
Yes I ran off the power beyond, it was within 100 pounds of the #7 John Deere hoe
/ JD855 - What Backhoe other than #7? #9
I do have stickers and green paint so it will be a green number 7 hoe eventually
/ JD855 - What Backhoe other than #7? #10
To the original poster, there is a No. 7 for sale near me now. I can see that I am nowhere near you, but at least this may provide a little hope to you that they are out there and do come up for sale now and then.
/ JD855 - What Backhoe other than #7? #11
The key to remember if attempting to retrofit any hoe to the x55 series is the necessity of a sub-frame. The x55 rear case/3pt simply isn't stout enough withstand the forces generated from using a hoe. The sub-frame distributes the load throughout the rest of the tractor's frame.
2017 Kia Cadenza Sedan (A61574)
2017 Kia Cadenza...
2022 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2022 ASV RT-25...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
Mounting Plate Skid Steer Attachment (A61572)
Mounting Plate...
1996 Vermeer V-3550 Ride-On Trencher (A61572)
1996 Vermeer...
2017 Mercury SeaPro Outboard Boat Motor (A61574)
2017 Mercury...
