Front end loader stutters badly while raising.
   / Front end loader stutters badly while raising. #1
LA Bubba
JD 5105
My JD 5105 front end loader suddenly started "stuttering" while being raised. The 3-pt hitch is also doing it. The hydraulic reservoir is full. However, the hydraulic fluid has never been changed. Could that be the cause? Why so sudden? Hydraulic pump???
   / Front end loader stutters badly while raising. #2
change your fluid and filters then diagnose from there
OK. Everything going fine, almost. I drained the hydraulic fluid and changed the big canister filter. Now I'm fighting with the sump screen. It just pulls out, right? I am afraid to grab it with pliers and mess up the outer rubber seal. Any tricks?
   / Front end loader stutters badly while raising. #4
I am not familiar with your Deere, but on other JDs, the inlet filter screen just pulls out, yes. It may
be resisting cuz there are debris on the outside of it. If you can open the rear of your case by pulling
off the PTO plate, that will help to clear out the sump. I have seen a lot of crap collected inside tractor
sumps. If your inlet screen DOES have a lot of debris on it, you should clean out the sump anyway.
Your symptoms are classic oil starvation symptoms. I get those if I drive up a really steep hill while
trying to operate my FEL.
How many hours on your unit?
You're right. It just pulled out. Just required excessive force.
The tractor is old. I bought it around 2001 I think. BUT ONLY 19X hours. Yes that's 3 digits, slightly less than 200 hours. I'm new to this forum (any forum). Did the picture go through?
   / Front end loader stutters badly while raising. #6
That is what I expected. Your photo is clear. IMO, you must clean your sump. It is gonna
be ugly.
be ugly.
Yes. I had a couple of old partial gallon bottles of hydraulic fluid in the shed. I flushed those through. I'm planning on doing the whole exercise again next year mostly just so I can get a look at that screen. I wish I could pull the screen without draining all 9 gallons of fluid.
   / Front end loader stutters badly while raising. #8
I will never believe that tractor has less than 200 hours with crap like that on the filter. It looks like a big turd. I changed mine at 400 hours and all I can see is a couple little specks maybe 1/8" size.
Now that you flushed and changed your filter and fluid it may take a couple changings to get clear. Oil is a lot cheaper than having tranny problems.
Hmm. Deere Dude provides an interesting data point. About a year ago the bucket cylinders started leaking due to seal dry rot. I pulled them off and took them to a hydraulic shop to be rebuilt. I wonder if rain got in there in the interim. Although it only has 200 hours on it, it is 17 years old.
   / Front end loader stutters badly while raising. #10
:welcome:
Welcome to the forum!
:tractor: I'm going to move this thread over to our John Deere section.
2011 Ford Ranger Ext. Cab Pickup Truck (A55852)
2011 Ford Ranger...
2019 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A55852)
2019 Ram 1500...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A56129)
PEMBERTON...
2018 Bobcat T590 Compact Track Loader Skid Steer (A55851)
2018 Bobcat T590...
KUBOTA M7-132 (A53084)
