Trouble With Loader
/ Trouble With Loader #1
New York
Massey Ferguson 1742 Hydro with cab
I was using the grapple and noticed the loader arms would not lower. While grappling, I do not recall hitting anything hard or abusing it (ramming something). I checked the connections at the hydraulic ports and I also checked to see if the hoses were kinked. Everything looked ok (From the eye of a novice). The other three functions (raising, roll back, and dump) all function properly. I'm using a rear remote for the grapple and that is working as well. After fiddling with the the joystick, if I position it in one location, the arms sometimes lower. This is does not work every time, but most times it does. When I do this, I have to lower it very slowly. To get this to work, I have to approach the joystick delicately to find the right stop where it will engage Also when doing this, sometimes it lowers all the day down, other times it stops in about the same place. When I use the joystick to lower it, it makes a noise similar to when the bucket is in the max dump or roll back position. Any thoughts? Thanks
/ Trouble With Loader #2
Sounds like a quick coupler is messing with you. Might try shutting the engine down, relieving pressure on all functions and then make sure all quick couplers are fully engaged. The collars need to all snap back into locked position.
Thanks so much. I will give it a shot and report back
/ Trouble With Loader #4
Take the rubber boot off your loader valve and check linkage and that the spool is moving the same going in and out.
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
2023 CHEVROLET W5500 4X2 S/A 16FT FLOOR TRUCK (A67148)
2023 CHEVROLET...
2023 Tesla Model 3 Sedan (A66738)
2023 Tesla Model 3...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
2011 MAGNUM TRAILER LIGHT PLANT (A67714)
2011 MAGNUM...
CAT 631C Lift Cylinder (A68134)
CAT 631C Lift...
