John deere 425 starter issues
/ John deere 425 starter issues #1
weeder
Tuscola Illinois
John Deere 425 lawn tractor
Hi everyone, I think the starter in the 425 is going out, do I have to pull the engine to replace it? How can a person check the starter to see if it is the starter? Now it is mowing season so it figures something like this would happen! Ok I will sit back and wait for replys!!!!
/ John deere 425 starter issues #2
Maybe a better description of what the problem seems to be with the starter.. not much to go on so far.
Well when you turn the key to start the solenoid on the starter seems to not engage and then it does? Now after it has warmed upped the starter engages like it should. I saw a little smoke coming off the end of the solenoid on the starter today. I hope this helps!
Ok I will ask this....Has anybody changed a starter out in a 425 garden tractor? If so how did you do it? Thanks Weeder!!!!
/ John deere 425 starter issues #5
That smoke could be coming from a poor connection, I think there are fusible links down on the starter solenoid that provide power for the rest of the tractor.
/ John deere 425 starter issues #6
I'll ask.. have you tried to remove it?
Before I replied, I went to the shed and popped the hood.. took a few pics.
Looks to me that removal would not require removing the engine from the tractor. Two bolts shown with red arrow.
May need to remove a few things to get at the starter, but that routine just becomes part of it.
I have checked all of those and they are in good shape
That is very helpful I thank you very much!!!!
/ John deere 425 starter issues #9
Well there's the problem. Everybody knows that electrical stuff operates on smoke. When the smoke leaks out, it stops working.
/ John deere 425 starter issues #10
I have had the starter off my 425 many times. Don't enjoy the job but I found if you remove the coil it's easier to get to the bolts. Since this is a Japanese engine they are probably metric I used a box end wrench and you only can move it a fraction of a turn. It takes some to get the bolts (2) out. It takes a little twisting to get the starter out of the housing. I took my starter to repair shop and he checked it out and cleaned it. So after all the time it takes to remove and install the starter still acted the same. removed it again and took it back and he put a new bendex drive in it which he should have in the first place. It now works fine.
/ John deere 425 starter issues #11
Most of the time the starter is fine and the problem lies in the control and ground circuits.
If you do not diagnose this properly you will have a new starter with the exact same problem.
You need two cheap tools to do some simple diagnostic steps.
A multi meter for less than $10
A test light again for less than $10
The issue of smoke makes me think there is a dirty connection on the battery ground cable, .
A multimeter test when the engine is cranking will tell a lot.
John Deere has been selling kits to provide a stronger signal to the starter solenoid when safety switches start to become corroded.
You can easily make your own.
Get the meter and test light and come back for more instructions
There is a FREE engine shop manual for your Kawasaki engine.
Download Kawasaki FD62D Service Manual
Read this link for info about the starting improvement relay kit:
John Deere Starting Improvement Relay Kit - AM17421
Dave M7040
Got the starter out and had it tested at John Deere..the solenoid bendix was bad..so I just ordered a new starter...THANKS EVERYONE for the help!!!!
/ John deere 425 starter issues #14
Dave
In the list showing in your link, the JD 425 isn't on that list.. leaves one to wonder if the relay kit is not for the 425.
HYDREMA 912HM ARTICULATED DUMP TRUCK (A65056)
HYDREMA 912HM...
Unused 2022 HLA 60in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2022 HLA...
SHOP BUILT TRI-AXLE LOWBOY TRAILER (A63291)
SHOP BUILT...
2023 Polaris Utility Cart (A66738)
2023 Polaris...
2009 Case CX240B Excavator (A64194)
2009 Case CX240B...
2015 COTTRELL CAR HAULER (A67714)
2015 COTTRELL CAR...
