DPF
Tractorrr
Gold Member
TN
kubota bx 2370-1
Just watched a video of tractor time with tim on youtube. He went to a dealer that had mahindras in the higher hp range that didn't require DPF. He may have looked at some Massey Ferguson's that didn't require them as well. What is up with that? Will Kubota be coming out with tractors above 26 hp that don't require DPF?.
What year were the Mahindras?
hello Tractorrr. None of the mahindras have dpf .They supposedly spent 30 million dollars designing an engine that doesn't need it. I have 2 mahindras, aaaaaan 04 2810 and a 2017 2538.I have around 1000 hrs on the 2810 and it has been a great tractor. I have just 50 hrs on the 2538 so far so good.The engine on the 2538 has a lot of power,so far I have been impressed with it .
Take this for what it's worth, but I believe Mahindra purchased credits in order to buy more time until they were required to have a DPF. I heard this on the internet. :)
Purchased credits, I've never heard of anything like that. You need to read this and watch this video. They're using a Diesel Oxidation Catalyst to get their engines to pass emissions without a DPF. I believe some of their largest still have a DPF and DEF. Personally I think their on the right track as far as emissions, as long as they have to be built to meet this crap mandate.
The Mahindra mCRD technology
Introducing our Tier IV "mCRD Technology" | Mahindra
"mCRD Tier IV The Simple Solution"
mCRD Tier IV The Simple Solution - YouTube
Several of the tractor brands have been able to build engines without the DPF and still meet emissions standards. The New Holland T4.75 I wanted to buy before I ended up with my Kubota was that way, using a "Particulate Matter Catalyst" instead of a DPF.
It surprises me that Mahindra found something potentially better than everyone else. Even big truck and vehicle companies use DPF. Ford, John Deere, Cummins, etc certainly outspent Mahindra in designing these systems. I am generally curious why almost everyone gravitated in one direction.
I have no experience with the Mahindra system but I’m guessing it’s mostly marking hype. Think practically every other manufacturer went the same way and then Mahindra who generally doesn’t have the most refined machine found this new and better way?
Agreed
International used a similar setup with their Maxxforce truck engines.
High pressure common rail with EGR.
They had a LOT of issues from what I have heard. Resale valve on International trucks that have the Maxxforce engine are very low in my area due to issues.
Nothing majical at all. The lower HP tractors have less stringent emissions limits allowing egr valves, catalyst, and or dpf's. Kubot, Deere, and a few others decided to go the regen route. Who knows after 2-3 thousand hours which system is best. I just purchased a 1000 hour tier 3 New Holland t4.75 that only uses an egr valve. No issues with 1000 hours on the clock.
I'm not sure about Deere but Kubota builds same engine power ratings with and without DPF. There is no amazing technology nobody else has that allows Mahindra to sell a tractor without DPF. Kubota and Deere have both stated they opt to use the DPF versions in their tractors based on expectations. Burning soot requires higher heat so higher combustion temperatures will eliminate soot but it will create more NOX. Higher temps may affect engine life - but that can be compensated for by using more exotic materials. In my case my Kubota L6060 with DPF greatly outperforms the L5740 I had both in engine capability and reduced fuel consumption. A regeneration involves seeing the word Regenerating on my dash plus a light indicator. My last regen was 2 days ago cleaning up my yard, very low power re quirement, lists of shuttling back and forth. I've had larger DPF equipped tractors since 2013 with many regens and no problems. The engines cost more but maintenance costs are generally lower - example doubled or tripled oil change interval, virtually zero oil consumption as oil burning increases emissions. None of my DPF tractors have required adding oil between the 500 or 600 hour changes. I have not had one yet reach the 5000 hour mandatory minimum time before cleaning so I do not know how much that will be. Now that the EU is headed into Stage 5 what will the tractor company strategy be? Will they continue to build emissions compliant tractors common to EU, Japan and North America or will they make special EU tractors (DPF required)?
As for credits, they've been in place for every upgrade. A great deal of R&D is required for each change so to stagger the introductions companies have been allowed to sell non-compliant equipment for years after the deadline by producing cleaner than required engines for some machines and earning credits. They can also earn credits by implementing early on some machines. The emissions regs have also had flexibility over the years, depending on region, by engine build date vs tractor build date. They could stockpile up to a year's engines under the past stage and use them up in new tractors. Required that the engine build date meets deadline. We have one JD tractor on our farm bought new a year after Tier 4 final was in effect but meeting Tier 4 interim.
They must have had problems with that system, I have a 2016 t4.100 and it requires def.
Not positive because I have nothing which uses/used DEF, only ones that ReGen, but think I would like to use DEF over ReGen
I’ll be honest, I haven’t had any real problems at all with my tractor or skid steer that both use def, I think the key is running at a pretty high rpm to keep them hot...you def don’t want to let them idle all day long.
Guess I should also add, anything that ReGens also burns more fuel. Unable to understand how burning more fuel keeps the air cleaner
My Thought Exactly
Just make more money for the fuel industry and Gooberment.
anyone who claims not to have a DPF has a DOC.. which is 90% the same. Its a DPF that does not burn. It meets its particular mater (PM) requirement by running the engine extra hot so the exhaust stream is cleaner. It also uses EGR (exhaust gas recirc) to reburn the exhaust, which DPF does not need to do.
kinda drives me nuts, as companies use the burn cycle to strike fear into those shopping with a tractor. I sell both styles of emissions system, we don't have more or less trouble with any certain type. Key thing is the operator understanding the system.
Messicks is correct...
Kubota, Deere, New Holland, most others, they have their system down...
I used a WM 50 for 2 years with zero issues...
Just bought a Tier 3 t4.75 with 1000 hours and an egr valve...
Really like it so far...
2026 Spirit All Terrain Electric Bicycle (A61569)
2026 Spirit All...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
2015 Caterpillar 938K Articulated Wheel Loader (A61567)
2015 Caterpillar...
UNUSED WOLVERINE TDB-11-66W 66" QUICK ATTACH BKT (A62131)
UNUSED WOLVERINE...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
