Local source for 60 amp main fuse
/ Local source for 60 amp main fuse #1
MWB1564
Pacific Northwest
2007 CK30HST
Hello, does anyone know of typical source for the 60 amp main fuse on my ck30? I could order one online but I need to get this tractor going today or tomorrow. Do electrical supply stores stock these? Any other suggestions?Thanks.
/ Local source for 60 amp main fuse #2
Cars,trucks and rvs have 60 amp fuses,try your local auto parts or even Wal-Mart.
It really doesn't look like any kind of standard automotive fuse though, so I doubt if they would have it. I'll check just to make sure. Thanks.
/ Local source for 60 amp main fuse #4
Do you have a pic of it?
It says 60A 32v on it.
/ Local source for 60 amp main fuse #6
That’s a PAL female fuse, parts store should have them.
/ Local source for 60 amp main fuse #9
There was a spare one of those in my owners packet along with the owners manual. Is is possible you got one and put it away?
No luck there. I bought mine used and all I found besides papers and books in the packet was a new key.
Luckily they had the exact fuse at NAPA auto parts. Thank you to all that helped out. Hopefully this thread will help somebody else in the future. Part No. 782-2031
/ Local source for 60 amp main fuse #13
What does the fuse protect, and what caused it to blow? Was the fuse expensive? I have the same model Kioti.
Thanks, Dutchy
/ Local source for 60 amp main fuse #14
This fuse protects everything except the starter. The OP reverse connected the battery which allowed massive reverse current through the alternator rectifier, which blew the fuse (and maybe damaged the alternator). I think (at least) all of the older CK and DK models have this fuse; it is inline near the starter, probably wrapped in black tape. The fuse is a common automotive item, about $5.
Yeah, I may have indeed damaged the alternator. My battery is not being charged by the tractor, I have to charge the battery every time I start it. My belt was pretty worn so I went to NAPA auto parts to try to match it up and they gave me one that is just barely too small to get on there. Does anyone know a good source for the OEM part or the part No. of one that works? I'd like to eliminate the belt as the problem before I buy a new alternator.
/ Local source for 60 amp main fuse #16
That belt is hard to match up at an auto parts store unless the parts person is good at it. It actually has a metric measurement for length, width, and angle. I was unable to find one from an older Toyota, Nissan, etc., that would match. I just ordered from Michigan Iron and Equipment. a Kioti dealer.
OK, thanks. I was just getting ready to order one myself and then I thought if the alternator is bad then it would save on shipping to order that at the same time. I'm going to spend some time trying to nail down if the alternator is bad. It seems to me if it was bad the tractor wouldn't keep running for hours after I start it.
/ Local source for 60 amp main fuse #18
.... Does anyone know a good source for the OEM part or the part No. of one that works? I'd like to eliminate the belt as the problem before I buy a new alternator.
In case you don't know, there are several excellent, free, dealer-sponsored online parts look-up sites, like this one by MIE (a sponsor). Ignore the "quick parts search" and work through the menus on the left half of the page.
Also, if you remove the alternator and take it in, most auto parts places (e.g. Advanced, Auto Zone, O'Reillys, etc.) will check it for free.
Also, if you Google the alternator Kioti or nameplate part number you'll probably find one for MUCH less than the Kioti dealer price,
Thanks, that sounds like the most certain way to find out.
2025 Bobcat T650 (A64126)
2025 Bobcat T650...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
2010 John Deere 1720 (A64126)
2010 John Deere...
2014 Freightliner M2 106 Bucket Truck, VIN # 1FVACXDT4EHFV0598 (A65563)
2014 Freightliner...
40' Shipping Container (A66285)
40' Shipping...
Iranch IRET13 (A64127)
