Forks Titan pallet fork hay spear combo
   / Titan pallet fork hay spear combo #1
saray
chipley, fl
shopping
Been looking into hay spear found Titan combo forks, does anyone have them and what do you think?
   / Titan pallet fork hay spear combo #2
There's a thread (below) in the "Similar Threads" area, third one down with 24 replies. Maybe worth a look.
I have a combination fork/bale spears FEL attachment. The back frame remains the same, I just swap the forks for the bale spears when required.
IMO, using a bale spike with fork tines to lift/transport a round bale is just adding superfluous weight to the task.
   / Titan pallet fork hay spear combo #3
It's all about ft-lbs. When lifting at the load limit it matters. BTDT
   / Titan pallet fork hay spear combo #4
I'm on my 2nd sdr of Titan pallet forks. First pair ran off with my L3200. My new pair have the lugs for & came with bale spears. Have yet to spear any hay with em. But they work just fine with the forks on.
My L4060 barely wouldnt pick up my 1920lbs with my newly delivered flail on it. Moved (mostly pushing, less rolling on fence posts than I'd have preferred) a large shed I could barely pick up 1 side of as well. Forks held up fine.20171221_125820.jpeg20180418_184828.jpeg
   / Titan pallet fork hay spear combo #5
I have a set of their spear/forks. I got the 60” 5k lb forks. They have been great and are super useful. Now everything is on pallets. They spend a lot more time on the FEL than the bucket.
   / Titan pallet fork hay spear combo #6
I have a set of the 42” fork/ spear combo with 2 inch receiver. I believe they fixed the first issue I have with mine. The 2” receiver used to stick out about 3/4 of an inch and you cannot slide one fork across to the other side. The forks are great, but I have one issue with the bale spear now. The two small bolts that hold in the short spikes have both broken on me. They are grade 2 I think. My recommendation is to put in better bolts and put some never seize or oil on them.
CLAMP ON UNIVERSAL 42" FORKS (A54757)
CLAMP ON UNIVERSAL...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
16FT BUMPER PULL SPOOL TRAILER (A55745)
16FT BUMPER PULL...
2011 Toyota Camry (A55758)
2011 Toyota Camry...
2018 CAT 336FL EXCAVTOR (A55745)
2018 CAT 336FL...
