Oil & Fuel Kubota B20 - Engine oil overfilled? Yikes!!
   / Kubota B20 - Engine oil overfilled? Yikes!! #1
mzwillinger
PETALUMA
Kubota B20
Just got a B20 and doing an oil change before putting hours on it. Drained the oil, surprising little came out, est 1-2 quarts. Specs says 4.1 qt capacity. I changed the filter and added 4 quarts. I started the engine, let idle, then checked the oil level. It is very overfilled according to the dipstick, like twice as much as it should have. I am not sure what to do.
First I double-checked that I drained from the correct spot and yes, from the bottom of the oil pan. The pan seems small. Not sure if I should drain and re-fill according to the dipstick or just call it good with 4 quarts.
Advice??
   / Kubota B20 - Engine oil overfilled? Yikes!! #2
Unable to find just the B20, but did find the B2320 and 2620 and they use 3.1 Qt counting filter. My guess, as with any motor, you never get it all out, so maybe 2.5 to 3 would be max for a change
   / Kubota B20 - Engine oil overfilled? Yikes!! #3
I'd drain the new oil out in a clean pan and measure the volume, to see if it is more than what you put in.
Or put 2 quarts of water in your drain pan to see if it was close to what you remember. I'm guessing you underestimated the amount drained.
   / Kubota B20 - Engine oil overfilled? Yikes!! #4
Did ya drain both side of the pan?
   / Kubota B20 - Engine oil overfilled? Yikes!! #5
Kubota D950-A-DT diesel 3-cylinder liquid-cooled 56.6 ci [0.9 L]
Oil capacity: 4.1 qts [3.9 L]
Coolant capacity: 4.2 qts [4.0 L]
Ok, looks the dipstick stopper had slid to the top of the dipstick.
Now I can adjust it and get an accurate reading.
I am sure it was running very low on oil for a long time, hopefully no harm done
I measured the oil it had been running on, just 24 oz. Less than one quart
   / Kubota B20 - Engine oil overfilled? Yikes!! #8
   / Kubota B20 - Engine oil overfilled? Yikes!! #9
Glad you figured it out.
2010 VOLVO VNL TANDEM AXLE MID ROOF TRUCK (A45679)
2010 VOLVO VNL...
Cosmo 3pt, PTO Spreader (A47371)
Cosmo 3pt, PTO...
60" Pallet Forks, New (A47371)
60" Pallet Forks...
2025 JMR 40in Grapple Rake Mini Skid Steer Attachment (A49346)
2025 JMR 40in...
Vicon 3pt Fertilizer Spreader (A49251)
Vicon 3pt...
Farmall A 2WD Tractor (A49251)
Farmall A 2WD...
