Oil & Fuel Easy way to transfer hydraulic fluid from 5 gal buckets?
   / Easy way to transfer hydraulic fluid from 5 gal buckets? #11
Something to consider. Years ago I strapped a universal 12 volt electric pump to an 18 volt lithium ion battery, the kind for drills, etc. Put a switch and two hoses on it.
Now you can transfer fluids easily. I use it to fill mowers, tractor, etc.
Recharge battery in it's charger. You could always just clip lead it to 12 v battery, switch inline.
I just ordered two extra pumps online from Wal-Mart $10.79.
   / Easy way to transfer hydraulic fluid from 5 gal buckets? #12
I use one of these....no more 5 gallon aerobics. :)
Robot Check
Ed
   / Easy way to transfer hydraulic fluid from 5 gal buckets? #13
Robot Check
Ed
That works also, but I'm cheap :)
The electric pump is more versatile also.
I bought this battery with charger on clearance. It works well. You could use any li-ion battery, 12 to 20v...or just clip lead to the tractor , car, mower battery.
Just my penny's worth.
   / Easy way to transfer hydraulic fluid from 5 gal buckets? #14
The old bucket on the side trick!! Sounds like a good idea. Wish I'd known about it sooner.
   / Easy way to transfer hydraulic fluid from 5 gal buckets? #15
COme on ....surely this is not a serious question. We've had tractors in the past that you added 5 gallon every morning. The bucket doesn't weigh 150# . a funnel and start with the spout on top.
Sounds as like you should have fixed them , instead of pouring through oil.
   / Easy way to transfer hydraulic fluid from 5 gal buckets? #16
Thats in a perfect world where where the guy gets on his tractor a saturday and mows his yard . When its farming and a down tractor cost more than the few bucks a jug of Hyd oil cost You let the rough side drag. Those tractors were Wore out but they still got the job done . Plus you only needed to change a filter ever so often cause the fluid was fresh
   / Easy way to transfer hydraulic fluid from 5 gal buckets? #17
:thumbsup: KIS(S). No paraphernalia to maintain.​
   / Easy way to transfer hydraulic fluid from 5 gal buckets? #18
Just did the hydraulic/trans fluid change in mine plus front axle and differentials. Used most all of of four 5 gallon pails of oil. I used a GPI CP-5 hand pump which I got from tractor supply about 10-12 years ago. I paid about half of what they want for it now.
https://www.jmesales.com/gpi-cp-5-portable-piston-hand-pump/ It's fast, works great and empties bucket quickly straight into tractor, no mess.
   / Easy way to transfer hydraulic fluid from 5 gal buckets? #19
A siphon will work, but will be pretty darn slow, I would think.
Do you know about rolling a 5 gallon pail on its side and pouring from the high side into a smaller, clean container? A lot of people do not know this trick. I posted a link to a video about it earlier this year and got a lot of WOW comments, as many folks don't know this. I didn't until someone showed me, so here goes... hope it helps you out. Works with any liquid in a 5 gallon bucket with spout.
Excellent video! Like someone said above, I wish I had known about that earlier!
I pour from my 5 gallon buckets into a former 2.5 gallon Kubota Super UDT container, then pour into the tractor from that. A lot less weight, not so bulky and has a more comfortable handle that doesn't move. You can get it into far more places where a 5 gallon bucket won't work.
Another thing that helps is a long neck steel movable funnel to fill the port on the tractor; something about 18" long or so.
2016 Ford Taurus Sedan (A55853)
2016 Ford Taurus...
Eagle Weathervane (A55853)
Eagle Weathervane...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Kawasaki Mule 2510 4X4 Utility Vehicle (A55853)
Kawasaki Mule 2510...
Mini Excavator (A55787)
Mini Excavator...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
