2555 Tie Down points
/ 2555 Tie Down points #21
I assumed that the front was made of cast or I would have welded them
/ 2555 Tie Down points #23
Good point!! how can we tell if it is cast or not?
Spark test - hit it with a grinder... few orange sparks is cast, mild steel will spark like crazy and the color is more yellow.
My godfather (master welder) will hit it with a hammer; a thud is cast, a ring (dinging sound) will be steel.
/ 2555 Tie Down points #24
This is how I tied down the front of my mahindra 2555 cab tractor. hold.jpghold2.jpg
/ 2555 Tie Down points #25
loader cross member under the front and then get you a clevus for the back
That is how I tie down. The loader frame has a large hole in it for a chain hook. I think criss cross the front and clevis in the back.
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2018 Volvo VNL 760 T/A Sleeper Cab Truck Tractor (A61568)
2018 Volvo VNL 760...
2018 CATERPILLAR 315FL CR EXCAVATOR (A62129)
2018 CATERPILLAR...
DRIVEWAY ENTRY GATES (A60736)
DRIVEWAY ENTRY...
2008 New Holland T2420 (A62177)
2008 New Holland...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
