Water distribution to a bunch of newish fruit trees?
/ Water distribution to a bunch of newish fruit trees? #1
ning
Elite Member
Northern California
Branson 3520h
We planted a bunch of new fruit trees last year to replace gradual die-off from an old orchard, and also to add more varieties... and mostly because it sounded great and I'm an idiot and let people talk me into adding to my workload.
Last year I set up a temporary watering system using a few runs of ?5/8"? (0.7" I think actually) drip line with 1/4" coming off to each tree, and some tubing with 6"-spaced emitters in a circle around the new trees for 3gph run for a couple hours every few days; these are connected to a hose bib via battery timers.
This generally worked, but it was a mess and was obviously impossible to mow around. I'm looking to put something in that's permanent.
My thought at the moment is to rent a smaller trencher - 4" wide x 24" deep max.
Frost isn't an issue, as watering only needs to be done in late spring through fall, and there will be no water pressure at any other time.
Thought is to run pipe down the lines, and T more pipe to each tree, and have a stub-up where it won't get hit by a mower, and attach drip w/ emitters for now, and maybe bubblers later.
Biggest question is: Can I use poly pipe for this? It's cheaper and quick & easy to handle... are the joints reliable to put underground?
I also like the fact that poly is flexible and can tolerate less-than-straight "lines" better (our orchard isn't on a perfect grid); I know pvc can bend some, but poly is very cheap and so easy to connect up.
Any advice for this noob?
/ Water distribution to a bunch of newish fruit trees? #2
I don't see why poly wouldn't work. It's what we had from the well to the house in WV and It's what I used to run a line ending in a hose bib out to our garden. I blew it out when it got cold to keep from freezing. I used barbed fittings with ss hose clamps but I've seen new fitting designs in the box stores now that are just friction fit.
/ Water distribution to a bunch of newish fruit trees? #3
Only suggestion that I can make...... If you bury poly pipe, you run risk of critters eating it.I have experienced that before in Western Oregon.
Standard irrigation people when burying lines, use white PVC. At the outlets they run double elbows with the exit emitter. The double elbows, called "street elbow and funny pipe". This allows for flex in the system and makes repair work easy.
/ Water distribution to a bunch of newish fruit trees? #4
For portable, six-month to one-year irrigation use T-posts with sprinklers on top, supplied by garden hose. We use hose Quick Couplers on the feed hose, moving from one sprinkler to the next. With ten foot tall T-posts you have really wide coverage, maybe 50'. We use this irrigation hardware in our 1-1/2 acre Blueberry field. Simpler, cheaper than drip.
Multiple venders sell identical LOW QUALITY, asian made T-post sprinklers. I bought at Tractor Supply Company. I would buy higher quality if it was out there, but, alas, not.
((Rainbird (brand) should sell high quality T-post bases.))
I recommend letting these LOW QUALITY sprinklers turn through 360 degrees, rather than oscillating. They operate trouble free fairly long turning through 360 degrees, only a short time oscillating.
LINK: GroundWork T-Post Sprinkler at Tractor Supply Co.
Another approach:
http://www.tractorbynet.com/forums/customization/339913-water-garden.html
/ Water distribution to a bunch of newish fruit trees? #5
I have a orchard - 14 apple trees. We started with a buried system. PITA!!!! Plug ups - pocket gophers - broken fittings - wash outs - winterizing. I gave up and put large brass Rainbird brand sprinklers on T-133 posts. Strategically located - I easily covered all 14 trees with eight sprinklers.
Simpler - visual confirmation of operation - easier to maintain - a WHOLE LOT LESS WORK TO WINTERIZE.
The eight Rainbird sprinklers were put into use in 1984 and are still used every year. I've had to replace some of the garden hose that feed the sprinklers - mainly due to the sun.
/ Water distribution to a bunch of newish fruit trees? #6
I planted a 9 tree apple orchard two years ago and I went low tech. I picked up 3 five gallon buckets per tree, and drilled a 1/16" hole in the bottom near the outer edge of the bucket. I place the 3 buckets around each tree so the hole is closest to the trunk and fill them up. I do this once a week if we don't get any significant rain.
Bakeries often have 5 gallon buckets for free. They order cake icing in them.
Hopefully you get enough rain so nature takes care of watering them for you!
/ Water distribution to a bunch of newish fruit trees? #7
I do the same with the buckets. I was ready to give up on my fruit trees until I started watering and fertilizing the drip lines. Game changer for me.
/ Water distribution to a bunch of newish fruit trees? #8
What's your water usage costs there?
Sprinklers waste a lot of water through runoff and evaporation. Drip can be much more targeted and efficient. Also, watering daily encourages shallow root growth. Watering for longer periods less often will produce better, stronger root structure. I'd just run a poly pipe down the row of trees right along the trunks, then tee off a couple/three larger GPH emitters to each tree. If you don't want to mow around the tee'd off lines, you could put mini sprinklers in between each tree. One sprinkler would cover one side of two trees. Then you wouldn't have to mow around them.
/ Water distribution to a bunch of newish fruit trees? #9
I also use five gallon buckets. Just one bucket per tree, and they are filled up with a hose. We've talked about going with something that takes less time, but so far, it's just talk.
/ Water distribution to a bunch of newish fruit trees? #10
1/2" pe tubing for the main with 1/8" tubing punched in where needed with emitters on the end by the tree. pressure regulator and filter required but not pricey. hold the tubing close to the ground with staples. set the mower high enough to avoid hitting the tubing.
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2016 FORD F-550 XL SUPER DUTY UTILTY/SERVICE TRUCK (A59823)
2016 FORD F-550 XL...
2016 Isuzu Box Truck (A60352)
2016 Isuzu Box...
LIGHT TOWER (A56857)
2016 KOMATSU PC360LC-11 EXCAVATOR (A58214)
2016 KOMATSU...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
