Ballast when do i need wheel weights
/ when do i need wheel weights #1
geoffleach
Member
mountain ranch, ca
Antonio Carraro TRH 9800, TTR 4400
Is the reason that "more weight is better" or are there more complex decision factors. I ask because I've had a couple of situations where the tractor has dug itself into soft ground.
/ when do i need wheel weights #2
The idea - "more weight is better" - can relate to many things. In one instance - a heavier ground engagement implement will - generally speaking - do its job better and quicker. Example - I have two rear blades. Both are 96" wide blades. One weighs - 565 pounds, the other weighs 1050 pounds. The light blade will not cut thru the concrete like surface of my mile long gravel driveway in the summer. The heavier one has no problem.
I have a grapple on my tractor. It can lift 3000 pounds - BUT ONLY if I have sufficient weight "out back". I have 1550 pounds of Rimguard in my rear tires and my 1050 pound rear blade on the 3-point. That amount of weight IS NOT ENOUGH to offset a 3000 pound lift with my grapple. I can safely lift 2600 to 2700 pounds - the way it is set up now.
There are times when more weight may not be the ultimate answer - when you and your tractor are up to your elbows in a mud bog.
You need more weight when - lifting with your front end loader(FEL) - looking for more traction(other than stuck in mud), wheel weights, fluid in your rear tires, implement on your 3-point. Looking to increase lateral stability - this will involve fluid in your rear tires, wheel weights, weight on your 3-point AND widening your rear tire stance.
You dig into soft ground - you are in too much of a hurry to get out on the tractor. Wait a bit longer - let things dry out before you go into that area again. Weight won't help you here.
/ when do i need wheel weights #3
If you dig into soft ground - you are in too much of a hurry to get out on the tractor. Wait a bit longer - let things dry out before you go into that area again. Weight won't help you.
Does your Antonio Carraro TRH 9800 have 4-WD?
What tires? Do tires retain sharp tread?
The first rule of sustainable agriculture is do not compact the ground.
A most helpful exposition. Thanks.
BTW, I very much agree with your sig. Curious that one does not hear that often!
4-WD yes. By "retain sharp tread" do you mean does the tread retain its shape? If so, yes.
/ when do i need wheel weights #6
What type of tire is on your tractor?
R1/agricultural "bar" tires.
R4/industrial tires
Turf Tires
Radials
/ when do i need wheel weights #8
R1/ag tires provide best traction possible. Adding chains will improve R1 traction.
Downsides of wheel weights:
Increased soil compaction.
Cannot run over lawn turf with R1 tires due to marking.
A flat tires means dealing with a 700 pound wheel/tire combination. (Depending on tractor size.)
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
Peterbilt 379 with a CAT C13 (A63689)
Peterbilt 379 with...
2006 Dodge Charger Sedan (A64557)
2006 Dodge Charger...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
Freightliner Cascadia (A63689)
Freightliner...
2022 DEMCO KARKADDY X 9713093 CAR DOLLY (A64277)
2022 DEMCO...
