ISEKI TA437 HYDRAULIC PUMP
/ ISEKI TA437 HYDRAULIC PUMP #1
TAURINS
LATVIA
ISEKI TA437; CLAAS, VALTRA
Do You know where can buy ISEKI HYDRAULIC PUMP.
Pump number: GPLI-123R0.
/ ISEKI TA437 HYDRAULIC PUMP #4
Ouch, that IS a problem! I suspect you have already done an exhaustive search for this pump. The pump appears to be hard to find. I again would suggest contacting Sheafer's Town & Country Sales Department . The owner, Len Scheaffer is very knowledgeable and can sometimes get rare parts directly from sources in Japan. In the end, if you can't find a new pump, I would take the pump apart and take the broken shaft to a good machinist and see if they can machine a new one.
/ ISEKI TA437 HYDRAULIC PUMP #5
I think your pump was possibly made by Kayaba (KYB). I see that their gear pumps use part numbers that start with "GPLI- " on the pump bodies. You may try to find a company that specializes in KYB pump repair/rebuild/replacement.
/ ISEKI TA437 HYDRAULIC PUMP #6
I called Kayaba Americas and gave them the information. They would not confirm or deny that your pump is a KYB but as soon as I told them that the number on the pump started with "GPLI" and "Iseki" they stopped me and said that KYB does have "proprietary agreements" with Iseki and as such, information, parts or replacement pumps would have to come through Iseki. Have you tried an actual Iseki tractor dealer ( not just an Iseki importer/seller)? There are none in the U.S. but I am certain there are factory dealerships in Europe, Asia and Australia.
Give answer Sheaftractor and say help me.
YES, I write e-mails dealer from Europa,Asia but nobody answering.
What You think if I write to KYB about my problem because I this pump search two months (and write to Japan, Germany, Italia....)
/ ISEKI TA437 HYDRAULIC PUMP #10
Iseki in Australia was handled by AGCO so a Massey dealer here may be able to help you IF your model was one that was imported into here by them they are not real helpful if it wasn't an Aus model
Jon
2006 KAWASAKI BAYOU 250 ATV (A60430)
2006 KAWASAKI...
2017 FREIGHTLINER CASCADIA 6X4 TA SLEEPER TRUCK TRACTOR (A59914)
2017 FREIGHTLINER...
2014 KENWORTH T370 ROAD TRACTOR (A62130)
2014 KENWORTH T370...
UNVERFERTH H25 - 25' HEAD CART (A64277)
UNVERFERTH H25 -...
Landhonor SAD-12-23C Skid Steer Mount Auger (A62679)
Landhonor...
JOHN DEERE 5403 TRACTOR (A62130)
JOHN DEERE 5403...
