Hi all,
Bought my first tractor last summer, a little Mitsubishi MT180HD and it has been great for around the house so far. When I bought it, I went through and changed the coolant, engine oil & trans/hyd. fluid. Sometime later, I was operating the tractor when I noticed this buzzing/ringing sound coming down near my feet. After listening closer I found the pipe it is coming from (diagram below). The buzz/ring is not audible immediately upon startup. However, within 10-15 seconds it starts to build until it is at the level illustrated in the video (link attached). When the clutch is depressed, the buzz/ring stops.
I replaced the hydraulic fluid with Mystik 80w-90 from Farm & Fleet (image below) and replaced the hydraulic filter with a CAT 4T-6915 (manual calls for Donaldson P556005 but I could not find any around. I found several websites saying the CAT filter was approved equivalent, link below). I removed the hydraulic filter screen and cleaned very gently with diesel fuel and starting fluid. I was careful not to damage this delicate mesh. I do not remember this sound when I first bought the tractor, but then again I was new to the machine and also very excited to use it so there is the possibility that I was just oblivious to the sound at first.
I realize that tractors are big machines with a lot of moving parts & sounds, but this one seems distinct to me. I was hoping to get your opinions on the following:
1. First and foremost: Is this a concerning sound that requires immediate attention?
2. What is causing this sound?
3. If this needs to be addressed, what can I do to fix it?
After doing research my fear is that it could be cavitation and running the tractor any longer could damage the hydraulic pump. However the videos I've watched on cavitation do not sound the same as what I'm hearing on my tractor. I don't know if this is due to the majority of cavitation videos I found being on large scale industrial type hydraulic systems vs a little 18 hp tractor?
Below are pictures of the referenced information and a link to the video of this buzzing sound.
If I've forgotten to include any information please let me know and I'll respond.
Thanks in advance for the help!
Sconnie
Location of pipe producing buzzing sound
CAT approved equivalent for Donaldson p556005
FBW-BT8314 FILTER-Hydraulic(Spin On) - Buy Online - Next Day Delivery
Manual info on hydraulic fluid
80w-90 from Farm and Fleet
Video of tractor buzzing/whirring noise
Mitsubishi MT180HD Hydraulic Buzzing - YouTube
Sconnie
