Hydraulic colored covers for hyd lines
/ Hydraulic colored covers for hyd lines #1
eddieirvine
Indiana
Kubota L 3940
Where is a place to buy hydraulic covers for male and female hyd lines
/ Hydraulic colored covers for hyd lines #2
I have found this type of product many times using Google. Hydraulic colored dust covers
If there is an independent hydraulics shop anywhere near you, my suggestion is to go there first.
You need to get a model which is compatible with what is on your tractor.
In the same way, different styles of quick couplers will not mate with another style, same with the caps and plugs.
If no one local then talk to these guys
Quick Coupler Dust Plugs and Caps | Hydraulic Quick Couplers | Hydraulics | www.surpluscenter.com
Another manufacturer who sells to the local hydraulics guys
http://ph.parker.com/us/en/quick-coupling-dust-caps-and-plugs
Dave M7040
/ Hydraulic colored covers for hyd lines #3
I see them at Tractor Supply, although I haven't seen the orange covers. I bought mine at the dealership, they were better quality and more flexible.
/ Hydraulic colored covers for hyd lines #4
I've seen those at the Kubota dealership.
/ Hydraulic colored covers for hyd lines #5
My farm supply store carries them for the standard AG size couplers.
/ Hydraulic colored covers for hyd lines #6
Dave M7040
Where I have seen owners getting into trouble on this forum is when there is a power beyond line is on a FEL valve for example and now instead of 6 lines you have 7.
Only 4 of the lines are likely equipped with couplers, but marking the correct position of the others with paint is wise so the day you need to start changing hoses or removing a FEL valve there is no confusion
Dave M7040
/ Hydraulic colored covers for hyd lines #7
I need new ones too. They get old after about 8 years outside...
My Deere dealer stocks them.
/ Hydraulic colored covers for hyd lines #8
Some fit nice, others don't fit at all. Some get hard really quickly. Some have chain and some have a plastic lanyard.
/ Hydraulic colored covers for hyd lines #9
Dave M7040
I've never heard of someone on here having that problem. Guess I need to visit more threads.
2003 Dodge Ram 4x4 Ext. Cab Pickup Truck (A59230)
2003 Dodge Ram 4x4...
Can Am Defender (A63688)
Can Am Defender...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2010 Ford Crown Vic (A62679)
2010 Ford Crown...
GYRO-TRAC (A65053)
GYRO-TRAC (A65053)
EZ Trail 3400 (A63688)
