3720 dashboard codes
/ 3720 dashboard codes #1
marshallcro
Member
Stanfordville,ny
John Deere 3720, Farmall Cub, Bobcat 3400
Could someone please tell me what the small blinking icon in the upper right of the LCD display that looks like an sideways hourglass or an "H" means also what does DEF means on the JD 3720 LCD. Thanks in advance.
/ 3720 dashboard codes #2
From the Owner's Manual: OMLVU25574_H2
Using the Instrument Panel:
MotionMatch (without optional switch): Available on eHydro machines only. Display will read "def" when MotionMatch is at factory default settings.
Changing MotionMatch Setting
1. Press and hold the display mode switch until the display reads “Release”.
2. Release the display mode switch and display should read “Coast”.
3. Press the display mode switch once again.
4. For machines without MotionMatch switch:
a. Push the turn signal switch and return to neutral position to change to desired setting between 1 and 9. Position 5 is displayed as “DEF”, the factory default.
TANK MANIFOLD (A58214)
2013 Ram 3500 Utility Flatbed Truck (A60352)
2013 Ram 3500...
FUEL PUMP W/NOZZLE (A60736)
FUEL PUMP W/NOZZLE...
832736 (A61166)
832736 (A61166)
2023 JOHN DEERE 317G SKID STEER (A62129)
2023 JOHN DEERE...
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
