Educate me on box blade size for uses
   / Educate me on box blade size for uses #11
I'll be buying or building a new box blade soon. I have a 60hp 4wd tractor that weighs roughly 8k-8.5k lbs with loader attached. I'm going with a stout design and need to know to go with a 7' or 8' blade. Tractor is 6' wide and my uses will be cutting swales, ditches, grading the drive, fields, yard (new grounds) and of course all the other uses for it. I've read where people have a slight controversy with going to wide for cutting swales or ditches, but I do like the idea of 8' for grading the drive that will loop the property totalling at least 4000 feet, haven't measured exact yet.
Ideas and opinions
You do not say if the tractor is equipped with hydraulic top and tilt...?
If not it won't take long to realize they are paramount for efficient box blade work...
Good Luck...
Good Luck...
Not yet, but very soon! Ran a tractor with it not long ago and that's the hot ticket with any ground engagement implement I learned quick.
   / Educate me on box blade size for uses #13
I have a similar question. I own a Kioti DK 5010HS its width is 62.8". Should I go with a 5.5' or 6' box. Mostly moving clay, topsoil, and about a 280' driveway 16' wide. I also need to cut a couple ditches in clay both about 400' long.
   / Educate me on box blade size for uses #14
Not aware of a 5.5' BB but use the 6' BB as it covers tire tracks.
   / Educate me on box blade size for uses #15
I use a heavy 7' on my Kubota which is 7.5' wide and on my Ford which is 6.5' wide. Works fine on both.
2023 RTVXG-850 SideKick (A56435)
2023 RTVXG-850...
2016 John Deere Gator (A55973)
2016 John Deere...
2018 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2018 ALLMAND BROS...
2015 SOMERO S-222 LASER SCREED (A52707)
2015 SOMERO S-222...
6" CONVEYOR BELT (A54757)
6" CONVEYOR BELT...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
