*help* Lucas cav injector pump govenor spring location *help*
   / *help* Lucas cav injector pump govenor spring location *help* #1
Welder93
Tidioute Pennsylvania
Ford
Hi
I have Lucas cav injection pump on my Perkins 3.152 engine. In the process of changing the gasket on the top cover of the pump I removed the govenor spring from the govenor plate which was located in the bottom hole. Then proceeded to pull the cover off and the other side of the spring popped off of the throttle linkage. And I am not sure which hole it was in. After researching online I found a chart where you can match the code number up to the chart to see what hole the spring is located in.
This is all the info I took off of the Tag on the pump:
Type: 622
DPA: 3230F550
SER: 37700 E66
MOD: 2643B129AW/8 1800
Other numbers stamped on the actual pump itself:
767A
49635
Any help would be appreciated!
Thanks
   / *help* Lucas cav injector pump govenor spring location *help* #3
Look for the bright spots where the spring was
Really can’t tell there is little to no wear on the linkage
   / *help* Lucas cav injector pump govenor spring location *help* #5
if im reading your model info correct your code is 8 .
   / *help* Lucas cav injector pump govenor spring location *help* #6
Spring code IS "8".. follow the chart.
   / *help* Lucas cav injector pump govenor spring location *help* #8
Gottcha thanks everyone
Hi I have a old David Brown I purchased with the pump dismantled and in a box I have rebuilt injection pump and do not know where the throttle spring should be located on throttle body.
   / *help* Lucas cav injector pump govenor spring location *help* #9
Sorry its a 996
   / *help* Lucas cav injector pump govenor spring location *help* #10
Don’t care what tractor mdl is.. I need the #a off pump name plate
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
TOYOTA 7FGCU25 LP SIT DOWN FORKLIFT (A50854)
TOYOTA 7FGCU25 LP...
2009 JACK COUNTY 130 BBL VACUUM  TRAILER (A50854)
2009 JACK COUNTY...
2014 VOLVO TRUCK VN SERIES (A50854)
2014 VOLVO TRUCK...
2018 Nissan Pathfinder SUV (A50324)
2018 Nissan...
2016 FORD F-450 9FT SINGLE AXLE DUMP BODY (A51222)
2016 FORD F-450...
