3-pt bouncing/bleeding
/ 3-pt bouncing/bleeding
I bought a seal kit for the rockshaft, just haven't fooled with it yet.
/ 3-pt bouncing/bleeding #22
Hey sikmusicfreak8 have you done the kit install yet? I have the same issue and would love to hear how it went.
Not yet, was just servicing the tractor and looking at the box. I'll be digging into that soon.
Odd part, is that sometimes it does it bad, sometimes not at all; sometime when warm, sometimes when cold. There's no consistency which I find out.
Well, at long last I am pulling the tractor up to the garage in about an hour to start this repair. I will try and take some photos and post up how it went. Wish me luck,
/ 3-pt bouncing/bleeding #25
I will be waiting for the pics My dealer tells me there is a safety valve in the same area that can cause the same indication .
/ 3-pt bouncing/bleeding #26
Good luck! I hope it goes smoothly for you. Can't wait to hear how the whole process works out.
Got it done, wasn't too bad. Just like Dave mentioned. Took everything apart to access the top of the rock shaft, the cover you need to take off is the one with the 3pt valve attached to it between your legs. The seal Dave mentioned was of course obliterated. So once the cover is off, just bounce the 3pt arms up and down to push the piston out, remove the old seal and guides, replace with the new ones, and reinstall. Simple process really.
/ 3-pt bouncing/bleeding #28
Well done Jason. Not a hard job at all if a person is not opposed to turning a few wrenches.
$120. The Branson seal had $27 written on it. Either way, just glad its fixed.
/ 3-pt bouncing/bleeding #31
My '09 3510 does the same thing. The 3 point system bounces unless it's fully lowered. I found that by moving the front loader up or down or dumping or curling the bucket will stop it from bouncing. It's irritating. I know I've taken a short video of it.. but it's late and I'm tired.
Sound like you need to do the same fix
/ 3-pt bouncing/bleeding #33
It's the piston seal. The seal is leaking oil by and the system knows it is supposed to keep the position of the three-point arms...so it lifts them, then the oil leaks and it drops, so it lifts them again. Pretty easy fix.
/ 3-pt bouncing/bleeding #37
View attachment 548096View attachment 548097View attachment 548098View attachment 548099View attachment 548100
what exactly did you have to remove to access it..?
I removed the seat, plate beneath it, and the plate the covers your MFWD and PTO lever, then finally the bracing that holds the seat.
How is that done ? by hand lift and lower the arms?
Yes, just grab the arms by hand and bounce it up and down (not violently, you'll see it coming out slow with each up and down motion)
2019 HINO 268 4X2 S/A 26FT BOX TRUCK (A67148)
2019 HINO 268 4X2...
2022 EZ-GO ELITE...
2021 KUBOTA KX080-4 SUPER SERIES 2 EXCAVATOR (A65053)
2021 KUBOTA...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2022 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2022 KENWORTH T680...
2016 Ford Taurus Sedan (A64194)
2016 Ford Taurus...
