Wheel repair
/ Wheel repair #1
Jeff F.
Gold Member
Wisconsin
Kubota BX 2660 and B3200
I purchased new front tires for my B3200 and waited to have them installed on the rims due to snow and needing the tractor for snow removal. Last Monday I had it done thinking we were done with anymore large snowfalls. When I was installing the new wheels, I stripped a stud. I removed the stripped stud and ordered a new stud from the Kubota dealer on Tuesday morning. He thought it would be in stock by this past Friday. It wasn't and he assured me it would be in on this coming Monday.
Now to my problem. We received about 7 inches of heavy snow on Saturday and I plowed the bare minimum with the skid steer. It took forever and I damaged my lawn. It's now Sunday and it's like a blizzard outside. The weatherman is calling for another 7 inches.
Can I mount the wheel with the 5 studs and use my front mount blower or will I damage the wheel or hub?
/ Wheel repair #2
I would think you'll be fine with 5 of the 6 studs in place. I know cars do it all the time. You aren't doing high speeds so I say go for it.
/ Wheel repair
Thanks for the prompt reply. My other option is to use the 3 point blade on the tractor but then I will need to use the 4 wheel drive.
Would it be better to use the snowblower adding weight to the front tires or the rear blade and 4 wheel drive adding torque to the front tires?
/ Wheel repair #4
I'm with Dave. 5 of 6 will hold it just fine with the snowblower. Don't over torque the remaining studs, just make sure that they are properly snugged down and use it. Don't worry about it.
for your question, 4x4 torque can put a a lot more load on the studs than an increase in weight does. However, the 4x4 torque is theoretically constant during each wheel revolution whereas load due to the weight not only varies but reverses with each wheel revolution.
Interesting mechanical problem. I wouldn't worry about either.
rScotty
/ Wheel repair #5
I've driven with 1 lost lug on my vehicles before. Do I recommend it? No. But to get around you gotta do what you gotta do. As long as it's torqued, temporarily losing 1 isn't too big a of deal. On a tractor, you'll be fine.
/ Wheel repair #6
I wouldn't hesitate for a second, snow blower or back blade, 4x4 or 2 wheel drive.
You'll be fine.
/ Wheel repair #7
I agree with everyone. The wheel is designed to be hub centric. That means the hub has a raised edge that the wheel tightly fits over. The bolts mostly hold the wheel from spinning on the hub. If the design was bolt centric, then I'd worry.
/ Wheel repair
The forecast is now another 5-9 inches on top of all we already accumulated. We will be approaching 20 inches by the time the storm ends at least. It's almost whiteout conditions now.
I'm heading out to my shop to install the wheel on 5 studs. Then I will drop the loader and put the blower on.
Thanks for the advice.
Jeff
/ Wheel repair #9
Jeff
Be safe out there Jeff!!!!
/ Wheel repair #10
Another possibility might be to use a bolt as long as you can match the treading and add washers to fill the remaining space.
Might make you feel better.
Otherwise I agree with others, use it minus that missing stud.
Since you use a front blower you won't be excessive side loading.
\Were U pushing with an angled plow I'd be concerned but this is not your case.
/ Wheel repair
Thanks everyone for the reassurance. I worked for about 20 minutes then rechecked the torque on all 5. Everything was holding.
I was almost finished with my drive way and a neighbor stopped and asked for help. I did his driveway also. I just don't understand why some people move to the country and then not buy the equipment needed for living out here.
Thanks again
Jeff
/ Wheel repair #12
Yep , then they want to mow 5 acres and maintain a 1000 ft. drive . And budget 2000$ for a tractor .
/ Wheel repair #13
My neighbor at the farm is that way. I do a lot of tractor work for them. She's now widowed. Living on 40 acres of pasture/timber with only a lawn mowing tractor. I had a recent conversation with her about buying a tractor. Something in the CUT 30HP range with an FEL and MMM. Our local JD dealer had 3, each different size, starting with a 1025R and going up. I told her to go visit the dealer and touch each of them so she'd know what size actually is. Then come talk to me and I'd try to guide her...... The other day she said she was buying one. She was happy because it had the same size MMM as her current mowing tractor which she is trading in. 54". I had no comment. She has went and purchased the 1025R tractor I'm guessing. Can't imagine you could get a 2 series or 3 series with a 54" deck. So now she's making payments on a $17K (?) SCUT that still can't handle maintaining the 40 acre property. But then, I'm sure she doesn't understand this as a problem since she can ask me to brush cut her pastures..... Which I'll do..... Then I'll complain about it here on TBN. :)
2025 SDLanch SDLE20 Diesel Mini Excavator (A60352)
2025 SDLanch...
Hays LT1 Tender (A61307)
Hays LT1 Tender...
SDLL30 skid steer with bucket (A56857)
SDLL30 skid steer...
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
2019 VOLVO SD115B SMOOTH DRUM ROLLER (A62129)
2019 VOLVO SD115B...
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
