Simple question from a simple guy
   / Simple question from a simple guy #1
def38
woods and mountains of Alabama
M-F 231S
I am attempting to remove the knob on the rotary headlight switch on my 231 but, I cannot see the set screw to determine the head type; blade, Phillips, hex or whatever. I've tried poking several things into the set screw hole but, nothing turns the set screw.
Help someone.
Thank you.
def
   / Simple question from a simple guy #3
Get a little bit of playdough from the grandkids and roll into small ball press into the hole and leave it there for a second then very very gently pull out without deforming it you should now be able to see what kind of screw and if it's an Allen key you can compare size with impression
   / Simple question from a simple guy #4
I often use phone camera to take picture to see something like that clearly
   / Simple question from a simple guy #5
Might try a brighter flashlight......
B. John
I have to agree. Get one of those really bright led flashlights. If you ever own one, you will throw rocks at a conventional flashlight. Some of these new phones have an led flashlight. My phone has one and i've used on several occasions instead of a drop light.
   / Simple question from a simple guy #6
most older tractors had a flat head set screw . but I have seen allen screws also
Danno, there is no straight path to the set screw and so any impression will be ruined by the time i get it out of the hole. The access hole to the set screw is about 1/8 " diameter.
   / Simple question from a simple guy #9
As mentioned above is there any chance of getting cell phone camera in place and take picture? Beauty of this is one you have picture you can "zoom" in to look at fastener . The other old trick was to take silicone sealer and place in hole and let it cure (leave yourself a good size handle to pull it out) the problem with this on a 1/8 hole is that if silicone plug breaks in hole you will then need a dentist pick and half hour of playing dentist to get plug out!
It's probably going to take someone who has recently messed with the setscrew on his headlight switch knob.
Thanks to all so far...:thumbsup:
2019 CATERPILLAR 308 CR EXCAVATOR (A50458)
2019 CATERPILLAR...
2017 DITCH WITCH RT30 (A51243)
2017 DITCH WITCH...
John Deere (A50322)
John Deere (A50322)
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
2013 Chevrolet Traverse LS SUV (A50324)
2013 Chevrolet...
2018 HINO 268 26FT BOX TRUCK (A51222)
2018 HINO 268 26FT...
