Pulled this old Oliver out of the field...
   / Pulled this old Oliver out of the field... #211
Great job! You sure seem to know what you're doing (even if you are learning as you go). I would like to ask if you actually applied grease to the zerk on the steering rams? The fitting and the joint seem too clean. I wouldn't want you to have gone through that rebuild just to overlook something simple and ruin that mating surface.
   / Pulled this old Oliver out of the field... #212
Been following this from the beginning MD........ you are one of a bunch of guys on here that remind me how lazy I am :whistleblower:
Lookin' great !
Rgds, D.
   / Pulled this old Oliver out of the field... #213
Your recent pics reminded me to ask if the fuel filter is pointing the right way? I'm sure it ptobably is- but most have an arrow to show direction of flow.
And those new 3 treads look sharp on your restoration, Oliver! Maybe do a bling grille of shiny expanded metal. You know, the shark teeth and eyeball from some of the early fighter planes! :thumbsup:
shark teeth grill for tractor - Google Search
   / Pulled this old Oliver out of the field... #214
Now you can use that Oliver on your neighbors disc.
Nice job she's looking good.
   / Pulled this old Oliver out of the field... #215
Your initial pics of the tractor showed a grill that didn't look to be in too bad of condition. Was it worse than it looked?
Rob
   / Pulled this old Oliver out of the field... #216
I don't have any sources, but I am curious.
Which style of grill are you looking for, there's the one with the big square 3x4 "egg crate" pattern, or the one with about 9 horizontal round-ended slots, with two vertical slots on either side? Looks like the "egg crate" version may be a little easier to find...or make? Would you need the whole nose, or just clean up the dents in your existing nose?
   / Pulled this old Oliver out of the field... #217
Actually, his original grille looks like something out of a D-14/D-15 allis, but put on upside down?
   / Pulled this old Oliver out of the field... #218
I had to look for the difference online.
Bruce
   / Pulled this old Oliver out of the field... #220
Likely will need some weights on the front end of that tractor.
CFG Industrial QK16R (A53316)
CFG Industrial...
2000 Freightliner FL70 Manitex 14 Ton Crane Truck (A55788)
2000 Freightliner...
2016 Isuzu NPR Landscape Dump Truck (A55788)
2016 Isuzu NPR...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
New Wolverine 44" Mini Skidloader Flat Bottom Grapple (A50775)
New Wolverine 44"...
