Pulled this old Oliver out of the field...
   / Pulled this old Oliver out of the field... #211
Great job! You sure seem to know what you're doing (even if you are learning as you go). I would like to ask if you actually applied grease to the zerk on the steering rams? The fitting and the joint seem too clean. I wouldn't want you to have gone through that rebuild just to overlook something simple and ruin that mating surface.
   / Pulled this old Oliver out of the field... #212
Been following this from the beginning MD........ you are one of a bunch of guys on here that remind me how lazy I am :whistleblower:
Lookin' great !
Rgds, D.
   / Pulled this old Oliver out of the field... #213
Your recent pics reminded me to ask if the fuel filter is pointing the right way? I'm sure it ptobably is- but most have an arrow to show direction of flow.
And those new 3 treads look sharp on your restoration, Oliver! Maybe do a bling grille of shiny expanded metal. You know, the shark teeth and eyeball from some of the early fighter planes! :thumbsup:
shark teeth grill for tractor - Google Search
   / Pulled this old Oliver out of the field... #214
Now you can use that Oliver on your neighbors disc.
Nice job she's looking good.
   / Pulled this old Oliver out of the field... #215
Your initial pics of the tractor showed a grill that didn't look to be in too bad of condition. Was it worse than it looked?
Rob
   / Pulled this old Oliver out of the field... #216
I don't have any sources, but I am curious.
Which style of grill are you looking for, there's the one with the big square 3x4 "egg crate" pattern, or the one with about 9 horizontal round-ended slots, with two vertical slots on either side? Looks like the "egg crate" version may be a little easier to find...or make? Would you need the whole nose, or just clean up the dents in your existing nose?
   / Pulled this old Oliver out of the field... #217
Actually, his original grille looks like something out of a D-14/D-15 allis, but put on upside down?
   / Pulled this old Oliver out of the field... #218
I had to look for the difference online.
Bruce
   / Pulled this old Oliver out of the field... #220
Likely will need some weights on the front end of that tractor.
2018 FORD F-350 (A55745)
2018 FORD F-350...
2015 Ford F550 Service Truck (A52377)
2015 Ford F550...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A55302)
Neckover GL24-2-7K...
2005 Ford Explorer 4x4 SUV (A55758)
2005 Ford Explorer...
2015 SKY TRAK 6036 TELEHANDLER (A56129)
2015 SKY TRAK 6036...
70pc. 12ft.x 3ft. Black Metal Roof Panels (A55758)
70pc. 12ft.x 3ft...
