ACS problem pedals locked
/ ACS problem pedals locked #1
Roscoe294
I've looked at past threads about ACS and could not find the answer to my problem. I have a 2002 S250 that has been operated solely by hand controls for over 10 years.
I want to switch to foot pedals but when I do I cannot get the pedals to unlock. With the machine running, seat bar down, and in full operation mode I hit the switch to convert from hand to foot and I get 3 beeps and the lift and tilt light goes dark. I then hit the full operation button (green) and the lift/tilt lights back up but I have no pedal movement. When I hit the switch to convert back to hand controls I get the same thing, 3 beeps, light out, press green button, light on, then I have hand controls. I checked for error code(s) and it reads NONE. If I shut the machine down in pedal mode and start back up I still have no pedal movement.
Any help is appreciated.
/ ACS problem pedals locked #2
Pull the pin on the pedal linkage to the sensor and confirm the pedals move freely. I have encountered that issue many times. The pedal pivot rusts up. :thumbsup:
/ ACS problem pedals locked #3
Whenever mode is changed with seat bar down does require re-engaging Press to Operate button, part of the system design. As Jabonee stated pedals could be rusted in place or the pedal locks are seized, if the controller senses correct voltage through magnetic coil to ground there would be no code. Controller cannot determine is the stem actually moved or not.
Thanks guys I'm thinking they are rusted in place since I had to dig them out to locate them. The machine is new to me and the former owner really neglected it. Its getting a timing belt replaced and when I get it back I will check the rust.
Pedals were rusted into place. After a lot of lube I got them working again. I know have my ACS restored. A big thank you to Jabonee!!!!
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2015 IC Corporation PB105 School Bus (A61568)
2015 IC...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
Topsoil Trommel (A57453)
Topsoil Trommel...
2018 HYUNDAI VC2530152-JS DRY VAN TRAILER (A59575)
2018 HYUNDAI...
