john deere 4052R dash diagnostic codes
/ john deere 4052R dash diagnostic codes #1
4052R
depew ny
4052R
Hi, I have a new 2017 4052R john deere, I need some help. My tractor is at the dealer for the last 8 week to correct 6 error codes. They took the tractor because I had a dash code that said ptr a The tractor would not move forward, backward and had no power steering with this code.There was no number after the ptr a code. The dealer came out to my house and did a diagnostic scan with his laptop and that's where we found the additional 5 error coded. My question is, what should I be seeing on my dash when the tractor has error code? The tractor would not let me scroll thru and get any additional numbers or codes. If the tractor has 6 errors shouldn't I see that message on my dash? That one code went away and the tractor worked fine if I turned it off and started it back up. It seems like there are problems with the tractor and it's not showing up on my dash????? The codes that I am getting are not all related to one another.
I asked my dealer these questions and he could not answer them.
Thank you for your help
4052R
/ john deere 4052R dash diagnostic codes #2
I have no experience with the late model JDs so I can't really help. But from what you describe, I would guess it has to do with faulty electronics (computer system), rather than mechanical issues.
Thanks for the reply Oldoak,
I think it maybe a little of both. They have replaced the power reverser switch, speed sensor switch on the crank and now they are replacing the steering control valve.
It's a shame because I only have 50 hours on the tractor.
Thanks
4052R
/ john deere 4052R dash diagnostic codes #4
Shame indeed and how disappointed you must be after purchasing a new tractor. I would expect better from JD, a premier tractor manufacturer.
/ john deere 4052R dash diagnostic codes #5
I'm not defending the dealership... however electronic/computer control is a different 'kettle of fish' and they may be being fooled by a cascading fault. What I'm saying is that they are firing the "parts-cannon" at individual code faults whereas it could simply be a single fault that is causing the other faults to appear.
I say this from my experience as a Navy electronics tech. Your dealership may be overwhelmed (in their experience) by your tractor's presented fault(s).
Thanks Wagtail,
I understand what you are saying. My dealer is being advised by John Deere in how to address the repairs on the tractor. The thing that I don't understand is why the tractor did not display all 6 of my error codes on my dash. I had no idea there were 5 other codes until the dealer out to my house and did a computer scan.(did I buy the tractor with these error codes) The last I know is one of the fault codes have been cleared by replacing the crank speed sensor. Replacing that sensor did not fix or clear that ptr a code that lead me to call the dealer in the first place.
Thanks for you help
4052R
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
2014 CATERPILLAR 140M2 AWD MOTORGRADER (A62129)
2014 CATERPILLAR...
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
2020 FORD F-550 CAB AND CHASSIS (A60736)
2020 FORD F-550...
2006 Nissan Pathfinder SUV (A61569)
2006 Nissan...
