To do... or not to do... 2001 Tahoe 199,000 ... no reverse
/ To do... or not to do... 2001 Tahoe 199,000 ... no reverse #11
Before I just drove it to the junk yard and get $250 for it, I would throw it on Facebook/Craigslist advertise it for $12-1300. Who knows, maybe someone out there has a transmission they can stick it and be good to go.
/ To do... or not to do... 2001 Tahoe 199,000 ... no reverse #12
There is a lot that can be repaired on a transmission with out buying a rebuild. Reverse solenoid? Some things can be repair by just dropping the pan..... any diagnostic codes?
/ To do... or not to do... 2001 Tahoe 199,000 ... no reverse #13
It will need an overhaul, do not buy a scrap yard trand, you will get all the issues that your current trans has.
Id wave goodbye. Sell private.
Good luck.
/ To do... or not to do... 2001 Tahoe 199,000 ... no reverse #14
As far as the problem goes the first site has some good info. Towards the bottom describes the no reverse problems. Sounds like a tear down to diagnose absent any codes. A rebuilt tranny looks to be anywhere from $1200-$1600 from a Google search plus labor, so say at least $2000 total.
Some dealers have a minimum trade value if it will drive onto the lot. I would take the $2000 plus any trade in value or sale price on Craig's List and get something newer, not necessarily new. You can get momma a really nice 3 year old Cadillac CTS for $25K-$30K. A new report shows the CTS to be the vehicle that loses the most value (51%) after 3 years.
P.S The white one has 8522 miles for $27,180.
4L6E Transmission Problems | GM Transmission Resource
4L6e tranny - Google Search
Tyler - Preowned Cadillac CTS Sedan Vehicles for Sale
/ To do... or not to do... 2001 Tahoe 199,000 ... no reverse #15
My father has a 1999 F-350 7.3L that has 185,000 miles on it.
In 2016 we put a 2015 F350 8' bed and step tailgate on it, that was $3500.
In 2017 spent:
$2500 on a 4R100.
$400 rear driveshaft
$1,300 on complete strip down and then re-assemble of front axle for carrier bearings, seals, U-Joints, ball joints, unit bearings. Gears were fine.
2018 was $3200 for new (not reman) diesel injectors, glow plugs, glow plug relays, under valve cover wire harness.
$11,000 in repairs in the last 4 years. I keep telling him to throw up the white flag. The door bottoms are going bad again and the cab corners are starting to blister. So in the next year he will be spending a few more grand on body work since he will not drive a vehicle with any exposed rust.
But that same money could have made payments on a much newer, slightly used truck that has nicer features. But, the guy loves his old Steelers truck!
I'm glad that's his truck, and not mine. Over the 2 years I owned my 227k mile Silverado I put a water pump, door lock switch, battery, headlight, wheel bearing, radiator, and had drop the transmission to put bolts in the torque converter that broke off. Not counting labor total repairs was about $300. My surburban has been family owned since it was new. It currently has 206k miles and has had 2 wheel bearings a water pump, a ABS module, a door lock switch, brakes, an air intake gasket, and probably some other things I don't remember. I'd say $1000 repair cost is being way generous. I've had my dump truck about a year and and it has 107k miles and has had an alternator, and water pump. I'm sure there's some small parts I'm forgetting and I didn't include fluid changes tires or brakes since any vehicle needs that.
/ To do... or not to do... 2001 Tahoe 199,000 ... no reverse #16
My wifes son had an older Expedition that had similar miles and it was becoming an issue for them. Junk yard offered them $400 for it, they cannot afford to go to a dealer and try to trade it in, so they put an add on Craigslist asking $1,000 and they took the first $800 cash that showed up at the door. They guy brought a tow rope because he was told it might not make it home.
To me, 200,000 miles on a vehicle is like 10,000 hours on a tractor. You can keep them running, but you have to be willing to work on them all the time, and not have to rely on it to work every day. If you put the money into fixing the transmission, you still have a vehicle with 200,000 miles on it and a long list of things are real close to failing. What do you do when your wife, or child cannot get it to start, an hour away, late at night? How many times do you want to deal with this happening?
/ To do... or not to do... 2001 Tahoe 199,000 ... no reverse #17
I’d have to disagree. A 10k hour tractor is pretty much guaranteed to be a piece of junk. My 200k vehicle is still reliable and might not have been the best idea ever but was taken on a 3k mile trip last year. It’s never failed to start with a cause other than a dead battery and had never left anyone stranded. I see pickup trucks all the time with over 300k miles and 400k is not uncommon.
/ To do... or not to do... 2001 Tahoe 199,000 ... no reverse #18
And I see tractors with 20,000 hours on them that are still on the job. But just because you can site a few cases where a vehicle is still running reliably after 200,000 miles does not change the simple fact that it's well worn out by then. Most rental yards sell off their equipment at 2,000 hours because after that, it's hard to make a profit on them. Car rental companies get rid of everything before it has 20,000 miles on it for the same reason.
The question remains, are you comfortable having your wife or daughter relying on a vehicle with 200,000 miles on it, out late, by themselves, an hour away from home? What if the vehicle has already broke down on them once? Now you know it will happen again, the question is when will it happen again, and how much will it cost you the next time?
/ To do... or not to do... 2001 Tahoe 199,000 ... no reverse #19
I would say that cars and trucks keep getting better and better. Used to be that a car with 100K was junk. Now you have engines with 250K that don't even burn a drop of oil. Seems the rest of the car falls apart around the engine nowadays. Or, when the transmission fails it doesn't make economic sense to fix it, like in the OP's case.
I have a Honda Ridgeline with 215K on it. Runs like new. I'd drive it cross country tomorrow without concern. However, for our daily 100mi round trip commute we drive a new Toyota Avalon. And when we drive separate cars, I always have my wife drive the new car. If the Ridgeline ever breaks down I want to be the one driving it.
/ To do... or not to do... 2001 Tahoe 199,000 ... no reverse #20
I don't have a wife or daughter, and new vehicles aren't immune to breaking down. And it's not a few cases. I see literally hundreds of vehicles for sale with over 200k miles and and plenty with 300-400k. If those vehicles became pieces of junk at 200k miles they would have probably been junked. My Silverado was piece of junk at 200k miles but it had a rough life and rust was starting to win the battle. I stick to my original claim that a proven reliable and well cared for 200k mile vehicle is a non issue.
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
2018 Multiquip AR-14 (A60462)
2018 Multiquip...
AGT Industrial STSD10 QA (A60463)
AGT Industrial...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
INSPECTION (A61165)
INSPECTION (A61165)
2016 RAM 1500 Pro Master (A60462)
2016 RAM 1500 Pro...
