Mahindra 1635
/ Mahindra 1635 #1
LMychajluk
Sullivan Cty, NY
Kioti CK3510SE
Hi, all! (First post, here.)
My family has some property w/ a house in NY that's mostly a weekend home, but may end up being a retirement home someday. It's ~35 acres w/ about 2 acres cleared, with the rest wooded, but w/ powerlines running through the back of the property, all on the side of a mountain. In the past, we've used a Simplicity Baron 23hp riding mower w/ a cart to mow and do chores around the house (tree cleanup, garden work, etc...), along w/ a small Mighty Mac chipper and a walk behind tiller. That was fine when there were 4-5 of us that could get together and take care of the place, but now it's just my brother and I, and we've been thinking of getting a small tractor to help get things done and save on time and wear and tear on ourselves. We would be doing things like tilling a small vegtable garden and a couple of small flower gardens / beds, maintaining fences and drainage ditches, maybe building some retaining walls and landscaping a bit, cleaning up downed trees in the surrounding woods (incl. removing occassional stumps), and lawn care (mowing, fertilizing, etc...). If I ever move there full-time, snow removal would be added to the list. Since there isn't someone living there full-time currently, storage of our equipment in a standard garage is a requirement.
I've been looking at the Mahindra Max26XL and/or 1526/1533 w/ loader and backhoe. (My brother, on the other hand, has been looking at the JD 1025R, though I think a JD 2-series would be more in-line with what we need). Size wise, the Max26 and 1526 seem to be OK to me, but my main concern is the PTO HP. Though I think either would run most implements I'd like to eventually get (tiller, post hole digger, core aerator, etc...), I would like to run a decent PTO chipper/shredder like the Wallenstein BXM32 to clean up some brush piles that have been getting out of hand, which seems to optimumly need a 25-35hp PTO(?). The Max26 won't cut it (no pun intended), and even the 1533 is just barely there, but the 1533 is getting into a bigger frame / weight, which I'm reluctant to do (ideally I'd like to be able to tow it on a 7000# Util trailer w/ a 5500# capacity). Before anyone says 'get a trailer-mounted chipper', I'm thinking the PTO unit is much smaller than a trailer unit of comparable power for storage purposes(?), plus one less engine to maintain (time is an issue).
So, now I've heard about the new 1635 for 2018 - 2017 Mahindra Dealer Meeting: Part 2
The 1635 is an all-new model replacing the 1533, but using the 1626 frame size. Notable improvements include a USB charger port, new seat, tool box, new style grille and headlights, and integration of the loader joystick into the fender cowl. Lower link arms have a telescopic option (standard on the 1640). Frame size on this series is larger than on the eMax and Max tractors. 1600 series tractors utilize Mahindra engines.
(By 'Mahindra' engine, I'm assuming the Mitsubishi engine?)
So, it sounds like just what I need! More power in the smaller frame (though I haven't seen a spec sheet yet). I like the idea of the fender-mounted joystick, and I'm hoping it will have seperate fwd/rev pedals. I know there's not much info on it yet, but I figured I'd start a thread to collect what people may know so far. Looking forward to see what you folks have to say!
/ Mahindra 1635 #2
No the engine is made in India by Mahindra while the balance of the tractor is made by Mitsubishi except for the tires, wheels, front end loader and back hoes which are US made. Kansas machine works for the loaders and hoes. The tractors are crammed into containers and shipped to one of several regional distributors where assembly is completed.
/ Mahindra 1635
Thanks for the quick reply!
I guess I had it backwards. I thought Mahindra made the tractor w/ a Mitsubishi-developed engine. But, the 'Mahindra' engine is the mCRD that they're so proud of, right?
https://mahindrausa.com/mcrd
/ Mahindra 1635
Hmm... Was doing a little more research over the weekend. I think I could probably run the BMX32 with the Max 26XL. Going with the smaller Max would also mean less $$$, smaller (& cheaper) implements that would probably be more manueverable around the house, and I could probably get a smaller trailer that would be more comfortable towing w/ my F150. Any comments on the Max vs the 1500s?
/ Mahindra 1635 #5
It all depends on what you want to do with the tractor and how much weight you need. Sometimes weight is as if not more important as power. Also find out who makes the max. If it's TYM it's not as nice as the 1500 which is made in Japan by Mitsubishi. Is this from that good dealer you described? As I said, dealer choice is very important.
/ Mahindra 1635
It might be changing for the MAX line in this year's model, but I the current model Max 26XL was built by and used a Mitsubishi engine (I think). This was the same engine as in the 1526.
From the link I posted above:
The premium offerings also come with Kukje power, with the Max 25SL open station and HST only, and the Max 26XLT open station variant with a choice of HST or shuttle transmissions. All Max 26XLT cab tractors will come with HST transmissions. Kukje power replaces engines previously from Daedong and are larger displacement engines running at lowered engine rpms. All engines used by Mahindra are EPA Final Tier 4 (FT4) compliant without the need for diesel particulate filters (DPF).
(This almost sounds like they're talking about the eMax series exclusively, and not the Max?)
The 1526 has a 3rd gear w/ the HST and a slightly larger frame than the MAX (being a 'compact' vs. 'mid-compact'). The 1526 has a slight advantage in FEL lift capacity as well, and I've read that the FEL is overall better than the Max (and some people have swapped the 1526 cylinders onto the MAX), but the MAX has the tighter turning radius.
Weight and power -wise, I think either will handle the light landscaping and brush clearing chores I'd like to do, but as I mentioned, it is a bit hilly around the house, so the larger (wider) 1526 (or 16xx) would probably be a plus.
Once I get to a dealer and compare them side-by-side, it'll probably come down to ergonomics and feel, as well as price.
/ Mahindra 1635 #7
Any word on approximate cost of this new 1635??
/ Mahindra 1635
Nothing yet. The dealer I was speaking to said he doesn't expect the new 16xx series to be available before the summer. He seemed to think it would be ~$5k more for the 1635 vs. the 1626, but I don't see it. I think he's basing that on the difference between the current 1526 and 1533, which goes up to a larger frame and from a 3 to 4 cyl engine (I also thought I heard that the new engine in the 1635 would be a 3-cylinders). I'm thinking the 1626 will be similar in price to the current 1526 (within $500 MSRP), and the 1635 maybe $1000-1500 more, given that only the engine would be different(?). But that could just be my wishful thinking...
/ Mahindra 1635 #9
If it was that cheap for the upgrade it would be amazing! I have been hounding my dealer for a 1626... because I am close to buying a Kubota L2501 and really wanted to compare them head to head. The L2501 is available NOW! My dealer told me the 1626's have arrived at the Chattanooga plant and he could expect to see them arrive at his dealership mid month... but he gave no promises....
/ Mahindra 1635
If they're already on shore, I'd hope that Mahindra would at least update the website with the spec sheets and MSRP prices soon.
/ Mahindra 1635 #11
Regarding the 1626... they didn't make any changes regarding specs over the 1526, it's all cosmetic, comfort changes. Dealer told me $350 more than the 1526 pricing.
/ Mahindra 1635
Yeah, wondering more about the PTO HP on the 1635. I can probably get by with 20HP, in which case I can get the 1526, but a little more would be peace of mind that I would be able to run just about anything I would need down the road, if it's not an arm a leg price difference. The fender-mounted joystick on the 16xx's would be worth the extra $350 for me, even if I stuck to a 26hp machine. Was also curious if they would put a slightly upgraded loader and/or hoe on the 1635 from the 1626, considering how Mahindra is always touting how they match the implements to the particular models.
/ Mahindra 1635
Just saw this quick video on the 1626 pop up on my Youtube feed - Mahindra 1626 - YouTube. Mostly just pics from various angles. Still no specs on the 1635 that I've seen...
Been looking at the Kioti CK3510SE in the meantime. Heavier than the smaller-framed 1500/1600s. I know that's usually a plus, but I'm not sure the added weight of the Kioti is ideal for my application (working near the house / on the lawn and in young growth forest), but the loader / backhoe specs seem better. I think pricing would be within a $1k or so of the 1626 (maybe less for the 1635). Going to be a tough call...lots of nice features standard on the Kioti, but a little more than I really wanted to pay.
/ Mahindra 1635 #15
/ Mahindra 1635 #16
I just heard from my dealer today.... they advised their 1626's have been shipped and should arrive in the next couple days... I might just actually get to lay my hands on a brand new to t hge market 1626 HST!
/ Mahindra 1635
Cool. They didn't mention anything about the 1635, did they? (Though, honestly, I'm about 90% sold on a Kioti CK3510SE at this point).
/ Mahindra 1635 #18
Well the answer became clear. I finally got to do the same test the new model Mahindra 1626. New for 2018. I did the same bale test with the 1626 as I had done with the L2501. 900# large square and a 5ft hog off the back of the Mahindra. At engine idle...using pallet forks, lifted it to full height without breaking a sweat..! Back end planted! So easy for it that I decided to try it without the 5' hog... 1626 lifted it to full height...again! When the Kubota would have tipped on it's nose... Wow what a difference! You see proof like that in front of you it's easy. I bought the 1626 in the spot! I'm excited for all it can do for me!! The L2501 is a nice tractor. It just plain doesn't lift like the Mahindra
/ Mahindra 1635 #20
Any news on when these 1635's are due for release, or any pricing or specs? My local dealer has multiple 1626's, but still doesn't seem to know anything about the 1635 at all. I'm going to be pulling the trigger soon on something....leading contender at the moment being Yanmar YT235....but I'd really like to see how the Mahindra 1635 compares to that, especially in pricing. I'd expect the Mahindra to be thousands less than the Yanmar, but probably similar specs.
2012 DIAMOND T TRAILER GOOSENECK TRAILER (A67714)
2012 DIAMOND T...
PORTA POTTY (A68842)
2022 WIFO WBGS Hydraulic Bale Grabber Skid Steer Attachment (A66734)
2022 WIFO WBGS...
2021 JCB 300T SKID STEER (A65056)
2021 JCB 300T SKID...
(4) 275 Gal Chemical Container (A64912)
(4) 275 Gal...
2007 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2007 INTERNATIONAL...
