   / Share Pics of People Hauling or Towing Something Wrong #7,361
Oops.
They got half the job done...
   / Share Pics of People Hauling or Towing Something Wrong #7,362
That is NOT the proper way to split a tractor, ouch $$$$$
   / Share Pics of People Hauling or Towing Something Wrong #7,363
Is there any economical way to fix that or is it just totaled?
I'm assuming transmission housing and/or engine block is going to need serious welding & machining. New clutch if somehow the crankshaft & I put shaft didn't get bent or busted. Lots of plumbing for fuel, heater/radiator, hydraulics. Throttle, steering linkages all shot.
   / Share Pics of People Hauling or Towing Something Wrong #7,364
That would depend on the skill of those involved. If someone is skilled at working with cast, perhaps a repair might not exceed the value. I personally wouldn't trust the repair though.
The way I see it, one of two things happened... One; that tractor has seen a very hard life and the castings are likely full of tiny cracks. It was just waiting on some big jolt to break it. Fixing what broke doesn't fix the other tiny cracks that may be next to let go. Or second; the owner didn't properly maintain the unit and ensure all bolts and fasteners were fully tight. When they started to pull, some of the loose bolts allowed enough flex to break the tight bolts and when they broke the rest let go as well.
Either way I'd only use parts off of it on another like it. I'd consider it too broken to waste the time on attempting a fix.
   / Share Pics of People Hauling or Towing Something Wrong #7,365
I'd post it for sale on Craigslist with a note stating "ran when I put it away".
   / Share Pics of People Hauling or Towing Something Wrong #7,366
I question whether the back half of the tractor sank into the lake.
   / Share Pics of People Hauling or Towing Something Wrong #7,367
I found that on Reddit.
Towing a tractor with a rope : Wellthatsucks
Don't believe anything there, it's mostly kids posting as if they know something - that they saw in a video game! In some cases someone comes along who really is a specialist in the issue discussed but its up to you to sort out which is which.
One of the comments was it's in Russia and the the tractor appears to be a Belarus, likely old, from the USSR days. Slapped-together quality when new 30 years ago and now not not worth very much after repair. And it does look like the transmission went underwater.
So if that's accurate, likely its future is parts.
   / Share Pics of People Hauling or Towing Something Wrong #7,368
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
208316 (A58375)
208316 (A58375)
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A56438)
2022 John Deere...
2021 VOLVO VNL300 DAY CAB (A59575)
2021 VOLVO VNL300...
