Dirt Moving Subsoiler Flips Sod - Looks Rough
/ Subsoiler Flips Sod - Looks Rough #1
FreedomFamilyFarms
Auburn, IN
Kubota B2710, Toro Z Master Commercial
Hello TBN! I ran a subsoiler on my place creating parallel lines on contour to catch more rain as it leaves the property. Its an ETA subsoiler on the back of a 27 HP Kubota B2710. The Kubota pulled the subsoiler just fine about 12 inches deep. What I didn't expect was the mess it left behind. Most of the sod that was cut flipped over creating a very lumpy texture. Is this expected or is there something I can do to keep this from happening again. I'll probably continue to subsoil periodically for the next few years.
Seedling Tree Planting - YouTube
/ Subsoiler Flips Sod - Looks Rough #2
Subsoil in the fall and then rototill just before planting. The planting goes way better and faster and the softer soil packs the roots better.
Your subsoiling issue is because the grass roots are ripping out and the ripper point is a little too wide. Rip in the fall and try to get a 1 1/2" tip that will disturb the surface less or just kill grass with roundup a month before ripping and that will disturb it less too., even with a 2" point. The best thing for us is the rototiller. The seedbed is perfect and we can really fly when putting in trees.
/ Subsoiler Flips Sod - Looks Rough #3
Sounds to me like you also may have your top link adjusted wrong. You want the top link adjusted so the ripper point is aimed slightly down when raised, but as it gets to digging depth it levels out. If you have the top link too short, the ripper point stays aimed down while at digging depth, which is what is raising the sod so much as it passes through. If you make the top link longer so the ripper is running parallel to the surface while at digging depth, you will find the tractor can pull it much easier and you can likely even go deeper. If that ripper point is pointing down as it digs, it will try to dig deeper; or if the tractor won't let it go deeper, it will push the soil up. If there is a lot of angle, it will turn the soil like a moldboard.
/ Subsoiler Flips Sod - Looks Rough #4
I have an issue with mine, but it's more related to pulling roots, so I have a blade to weld on the front of it. The blade will be angled to push roots downward as it cuts. If the ripper is a foot down, you shouldn't notice it on the surface other than a minor bulge. It may behoove you to sharpen the edge at ground level so that it cuts instead of tears.
/ Subsoiler Flips Sod - Looks Rough #5
Looks normal to me based on my subsoiling.
I'm using a Tufline 1S-24 at about 18 inches deep.
Subsoilers | Tufline
Here's a photo of my results:
/ Subsoiler Flips Sod - Looks Rough #6
I have seen many subsoilers that have been ground down to a knife edge on the front of the vertical arm to better slice through the wire grass and roots.
/ Subsoiler Flips Sod - Looks Rough #8
Opico Sward Lifter - Grassland Subsoiler - YouTube
Having a rolling coulter disc in front of the shank would reduce the amount of topsoil disturbance. I'm not suggesting you invest in something this elaborate but just wanted to show the concept.
That’s a great idea. I can imagine cobbling up some type of roller to follow the shank of the subsoiler...
/ Subsoiler Flips Sod - Looks Rough #10
That is a great idea. I can imagine cobbling up some type of roller to follow the shank of the subsoiler...
Unlikely. You would need around 400 pounds pressure bearing on a 9" roller to do any good.
A coulter in front of the subsoiler is a better idea. ETA sells plow coulters separate from the plows. Perhaps you can fab a coulter mount or modify a mail order Disc hanger from Agri Supply.
It is Spring. Rain will reduce the unevenness with time.
I concur with SYSOP in Post #3 and NPALEN in Post #8.
/ Subsoiler Flips Sod - Looks Rough #11
Sometimes a user will weld on a steel strip, maybe 1/4 x 1, onto the front of the shank, then grind a sharp edge on it.
Bruce
/ Subsoiler Flips Sod - Looks Rough #12
I worked up a pasture field August of 2017 that hasn't been worked since about 1990. It was as hard as concrete.
3 shank ripper about 26" deep.
Chisel plowed then disked & cultipacked.20170803_190228.jpg20170906_182020.jpg20170925_183316.jpg
/ Subsoiler Flips Sod - Looks Rough #13
I was wanting to see you running the subsoiler. What it looks like is that it’s much too wet. You really want to subsoil during the dry months to shatter the hard pan.
Also, you need to be getting down deeper than 12”. It looks like due to the mud, you can’t get enough traction to pull your subsoiler at its full depth. One again, doing it when it’s good and dry will help there too.
In this pic, the tip of the subsoiler is 20-22” below the surface and it still disrupts the surface. The point on mine is 2” wire and 10” long. It’s an old Ford.
Adjusting the top link is key to getting it to the depth you want and angled so it isnt turning the surface over.
/ Subsoiler Flips Sod - Looks Rough #14
I was wanting to see you running the subsoiler. What it looks like is that it痴 much too wet. You really want to subsoil during the dry months to shatter the hard pan.
Also, you need to be getting down deeper than 12? It looks like due to the mud, you can稚 get enough traction to pull your subsoiler at its full depth. One again, doing it when it痴 good and dry will help there too.
In this pic, the tip of the subsoiler is 20-22 below the surface and it still disrupts the surface. The point on mine is 2 wire and 10 long. It痴 an old Ford.
I have seen those Ford subsoilers around and always wondered if they work. At 22", that's a pretty good pull. What do you think of it and how hard would a 2 shank version pull at 12" deep? Any HP guess?
We're on black dirt here to a black dirt-clay subsoil and most only go around 12" deep. Any more and it tends to invert the black dirt.
/ Subsoiler Flips Sod - Looks Rough #15
As is the EA SS that OP is using. I have the same SS...
/ Subsoiler Flips Sod - Looks Rough #17
I use an old JD steel wheel sub. and go 36" deep here, ( would go deeper) , course I use AC 190xtd, OR the IH 806 to pull it.---Makes a mound, don't scatter chunks, but run it in fall when ground is real dry and the harder the better.---Sometimes after I sub, I follow with the moldboard plow an turn everything over.--In spring it's one pass with tiller and plant garden.---You can dig down and find the soft tracks that the sub left.---Plant roots will follow right down in there. thanks; sonny580
/ Subsoiler Flips Sod - Looks Rough #18
It’s a Cat1 subsoiler, but in 2Wd it’s all my 68 hp tractor really wants in my hard, never worked clay. I could send it about 3 inches deeper, but it snaps grade 8 shear bolts every 100 feet. At that pictured depth I still broke about a dozen shear bolts doing 10 acres. When it hits whats left of a rabbit brush root, the tractor stops for a split second and the tires spin just a little bit to bite down through the hard surface then it grabs and breaks the shear bolt.
It has done the trick though, water used to sit on top and pond, but this winter I’ve had no standing water at all and my pasture seed didn’t wash away.
I would think your machine could pull 2 12” shanks if you can get enough traction.
You will have to wait until the ground is hard and hasn’t been tilled. You won’t have much chance getting it done after the ground has been plowed or disced.
/ Subsoiler Flips Sod - Looks Rough #19
I now pull a 3X Brillion curved shank ripper with a 90HP JD with radials and weight and it's no sweat at 14" deep. Studies and field research here now shows that 12"-14" is optimum for this soil type so I'm thinking of just using a 70HP M7040 Kubota (with radials and weight) and a 2X lighter ripper. For the small acreage I now do it would fit on the trailer and haul easier. I've seen those Ford rippers and am tempted because I've never seen a bent one and they look lighter. They also look like they pull harder.
Overall, are you happy with that ripper?
/ Subsoiler Flips Sod - Looks Rough #20
Yes I’m happy. It’s done exactly what I needed and since I only gave $100 for it, I’m very happy. The guy got it with a tractor and he did not know what it was and advertised it for $100. I did not argue with the man.
Here is what it looked like when I bought it.
From the manuals I found, they started making these in 1957.
I cleaned it up, painted it and have replaced most of the original bolts with new grade 8s. Most of the originals were pretty corroded.
2016 John Deere 6155R (A64119)
2016 John Deere...
2017 JAYCO WHITE HAWK CAMPER (A67714)
2017 JAYCO WHITE...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
11 R24.5 Tires - Set of 2 (A68134)
11 R24.5 Tires -...
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
Unused 2023 Maybridge B7D 6ft. Chain Harrow Tractor Attachment (A66734)
Unused 2023...
